Ga door naar hoofdinhoud
Power Macintosh G3 Blue and White PRAM Battery Replacement
Wat je nodig hebt
  1. Power Macintosh G3 Blue and White PRAM Battery Replacement, PRAM Battery: stap 1, afbeelding 1 van 1
    • Unfortunately, I am unable to provide OG content for this step due to my Power Mac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White PRAM Battery Replacement: stap 2, afbeelding 1 van 1
    • Locate the PRAM battery.
    • The PRAM battery is usually at the top right corner of the logic board.
  3. Power Macintosh G3 Blue and White PRAM Battery Replacement: stap 3, afbeelding 1 van 1
    • Lift the battery out of the PRAM battery holder.
    • What I did to free the PRAM battery is I broke the plastic battery holder identical to the circled one on the other side of the PRAM battery, then I was able to free the PRAM battery. I couldn't get the PRAM battery to budge without breaking the holder.
    • Don't be worried, breaking the plastic holder won't cause much damage nor will it hinder the ability for the PRAM battery to stay in place. Only break one holder, though.
Conclusie
[deleted]
25.149 Reputatie
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 33
Altijd: 1,961
