Ga door naar hoofdinhoud
Power Macintosh G3 Blue and White Graphics Card Replacement
Wat je nodig hebt
  1. Power Macintosh G3 Blue and White Graphics Card Replacement, Graphics Card: stap 1, afbeelding 1 van 1
    • Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White Graphics Card Replacement: stap 2, afbeelding 1 van 2 Power Macintosh G3 Blue and White Graphics Card Replacement: stap 2, afbeelding 2 van 2
    • Remove the single Phillips #1 screw circled in the picture. Set it aside for later.
    • The graphics card is outlined in red in the second image, if you are confused on where this is.
  3. Power Macintosh G3 Blue and White Graphics Card Replacement: stap 3, afbeelding 1 van 1
    • Lift the graphics card straight out of it's PCI slot.
    • Be careful not to lift sideways, you can damage the PCI slot! Try your best to lift the graphics card straight up.
Conclusie
[deleted]
26.550 Reputatie
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 33
Altijd: 1,609
