Ga door naar hoofdinhoud
Power Mac G5 Top Left Cooling Fan Unit Replacement
  1. Power Mac G5 Top Left Cooling Fan Unit Replacement, Side Panel: stap 1, afbeelding 1 van 1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 Top Left Cooling Fan Unit Replacement: stap 2, afbeelding 1 van 1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 Top Left Cooling Fan Unit Replacement: stap 3, afbeelding 1 van 2 Power Mac G5 Top Left Cooling Fan Unit Replacement: stap 3, afbeelding 2 van 2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 Top Left Cooling Fan Unit Replacement: stap 4, afbeelding 1 van 3 Power Mac G5 Top Left Cooling Fan Unit Replacement: stap 4, afbeelding 2 van 3 Power Mac G5 Top Left Cooling Fan Unit Replacement: stap 4, afbeelding 3 van 3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 Top Left Cooling Fan Unit Replacement, Top Left Cooling Fan Unit: stap 5, afbeelding 1 van 1
    • Locate the top left cooling fan unit.
  6. Power Mac G5 Top Left Cooling Fan Unit Replacement: stap 6, afbeelding 1 van 1
    • Pull the fan straight out from its slot. You will need to remove two cables from the motherboard.
    • It may be easier to reach the cables if you remove the PCI guide (next to the fan unit) first.
  7. Power Mac G5 Top Left Cooling Fan Unit Replacement: stap 7, afbeelding 1 van 1
    • After pulling out the fan unit, the area should look like this.
Conclusie
20 andere personen hebben deze handleiding voltooid.
Salvador Aguilar
2.481 Reputatie
3 handleidingen geschreven
Cal Poly, Team 5-8, Forte Winter 2010 Lid van Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Leden
20 handleidingen geschreven
Één opmerking
Actually you do need to remove the plastic air deflector, as the fan in question is behind it.
Tim downing - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 24
Altijd: 19,103
