Ga door naar hoofdinhoud
Power Mac G5 CD-ROM Drive Replacement
  1. Power Mac G5 CD-ROM Drive Replacement, Side Panel: stap 1, afbeelding 1 van 1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 CD-ROM Drive Replacement: stap 2, afbeelding 1 van 1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 CD-ROM Drive Replacement: stap 3, afbeelding 1 van 2 Power Mac G5 CD-ROM Drive Replacement: stap 3, afbeelding 2 van 2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 CD-ROM Drive Replacement: stap 4, afbeelding 1 van 3 Power Mac G5 CD-ROM Drive Replacement: stap 4, afbeelding 2 van 3 Power Mac G5 CD-ROM Drive Replacement: stap 4, afbeelding 3 van 3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 CD-ROM Drive Replacement, CD-ROM Drive: stap 5, afbeelding 1 van 1
    • Locate the CD-ROM Drive on the top left corner of desktop.
  6. Power Mac G5 CD-ROM Drive Replacement: stap 6, afbeelding 1 van 3 Power Mac G5 CD-ROM Drive Replacement: stap 6, afbeelding 2 van 3 Power Mac G5 CD-ROM Drive Replacement: stap 6, afbeelding 3 van 3
    • Pull and rotate latches to the left.
  7. Power Mac G5 CD-ROM Drive Replacement: stap 7, afbeelding 1 van 1
    • Wiggle and pull out the CD Drive.
  8. Power Mac G5 CD-ROM Drive Replacement: stap 8, afbeelding 1 van 2 Power Mac G5 CD-ROM Drive Replacement: stap 8, afbeelding 2 van 2
    • Detach the first cable from the CD-ROM drive.
    • Detach the second cable from the CD-ROM drive.
    • On some models, the IDE cable is stuck to the top of the CD-ROM with foam tape. It is easier to unplug the IDE connector from the motherboard, and de-route the IDE cable as you remove the drive.
  9. Power Mac G5 CD-ROM Drive Replacement: stap 9, afbeelding 1 van 1
    • After the CD-ROM drive is removed, the area should look like this.
Conclusie
44 andere personen hebben deze handleiding voltooid.
Jessica Chaidez
8.052 Reputatie
3 handleidingen geschreven
Cal Poly, Team 5-8, Forte Winter 2010 Lid van Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Leden
30 handleidingen geschreven
2Gids Commentaar
Is it possible to use an IDE to SATA connector? I want to install my Pioneer BDR burner to potentially use the PMG5 for data disc burning only. Any thoughts?
nirv - Antwoord
Misleading title. I know how to unplug the drive, thank you very much.
I've replaced the original drive with a better one and the %#*@ tray is stuck because it's too high.
engineer2137 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 97
Altijd: 35,714
