Ga door naar hoofdinhoud
Power Mac G4 Quicksilver Optical Drive Disassembly
Wat je nodig hebt
  1. Power Mac G4 Quicksilver Optical Drive Disassembly, Opening the case: stap 1, afbeelding 1 van 1
    • The handle to open your computer is located on top of the right side panel.
  2. Power Mac G4 Quicksilver Optical Drive Disassembly: stap 2, afbeelding 1 van 2 Power Mac G4 Quicksilver Optical Drive Disassembly: stap 2, afbeelding 2 van 2
    • Grab the circular handle and pull outward.
  3. Power Mac G4 Quicksilver Optical Drive Disassembly: stap 3, afbeelding 1 van 1
    • Your computer is now open and ready for repair.
  4. Power Mac G4 Quicksilver Optical Drive Disassembly, Power Mac G4 Quicksilver Optical Drive Disassembly: stap 4, afbeelding 1 van 1
    • The optical drive is in the top left corner of the case.
  5. Power Mac G4 Quicksilver Optical Drive Disassembly: stap 5, afbeelding 1 van 2 Power Mac G4 Quicksilver Optical Drive Disassembly: stap 5, afbeelding 2 van 2
    • There are four screws to be removed.
    • The first screw can be seen in the first picture.
    • The remaining three screws can be seen in the second picture.
  6. Power Mac G4 Quicksilver Optical Drive Disassembly: stap 6, afbeelding 1 van 1
    • Remove the optical drive by pulling the drive away from the front of the computer and out.
  7. Power Mac G4 Quicksilver Optical Drive Disassembly: stap 7, afbeelding 1 van 1
    • Detach the two cables attached to the back of the drive.
    • The flat ribbon cable can be detached by pulling the silver tab. The multicolored cable can be removed by grasping the plastic connector on either side and pulling with substantial force.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Jacob Garcia
621 Reputatie
2 handleidingen geschreven
Cal Poly, Team 14-41, Regan Winter 2010 Lid van Cal Poly, Team 14-41, Regan Winter 2010
CPSU-REGAN-W10S14G41
4 Leden
17 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 5,626
