Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
The Power Mac G4 MDD Uses a removable cage supporting up to two IDE SuperDrives.
Onderdelen
Geen onderdelen opgegeven.
  1. The Power Mac G4 MDD: the last, and the fastest G4-based Mac.  This computer boasted up to a Dual 1.42GHz PowerPC G4 CPU (though I have a single 1.25GHz). Two USB 1.1 Ports
    • The Power Mac G4 MDD: the last, and the fastest G4-based Mac. This computer boasted up to a Dual 1.42GHz PowerPC G4 CPU (though I have a single 1.25GHz).
    • Two USB 1.1 Ports
    • Assorted Audio
    • Video (ADC & DVI)
    • Networking (RJ-45 Ethernet/56k Modem)
    • Some later model MDD's (such as the dual 1.42GHz) Have a FireWire 800 Port Here:
  2. Unplug the computer. Unplug the power supply and all external connections from the computer. Pull on the side lever and lower the side of the case.
    • Unplug the computer.
    • Unplug the power supply and all external connections from the computer.
    • Pull on the side lever and lower the side of the case.
  3. The hard drive cages are located here.
    • The hard drive cages are located here.
  4. Cage 1 Start by removing this screw. Remove the ATA-66/ IDE ribbon cable from the motherboard.
    • Cage 1
    • Start by removing this screw.
    • Remove the ATA-66/ IDE ribbon cable from the motherboard.
  5. Now, remove the power connection from the drives. Now, remove the power connection from the drives.
    • Now, remove the power connection from the drives.
  6. Push this tab down, and pull the cage toward you. Now, you can set cage 1 aside. Now, you can set cage 1 aside.
    • Push this tab down, and pull the cage toward you.
    • Now, you can set cage 1 aside.
  7. Cage 2: Remove this Phillips screw:
    • Cage 2:
    • Remove this Phillips screw:
    • Disconnect this IDE ribbon cable from the logic board.
  8. It's likely that there is a cable clip holding the ribbon cable to the case. To remove it, push the end, and it should pop up.
    • It's likely that there is a cable clip holding the ribbon cable to the case.
    • To remove it, push the end, and it should pop up.
  9. With the ribbon cable clip free, pull this tab towards you, slide the cage up until it hits the platform under the power supply, and pull it away. Now, set the cage on top of the CPU, and remove the power connectors. Now, set the cage on top of the CPU, and remove the power connectors.
    • With the ribbon cable clip free, pull this tab towards you, slide the cage up until it hits the platform under the power supply, and pull it away.
    • Now, set the cage on top of the CPU, and remove the power connectors.
  10. Once the cables are free, set the drive cage aside. To remove the hard drives from the cages, remove the four screws on the sides of the cage that are connected to the drives, then slide the drives out.
    • Once the cables are free, set the drive cage aside.
    • To remove the hard drives from the cages, remove the four screws on the sides of the cage that are connected to the drives, then slide the drives out.
    • The two cages are cross compatible and can be put in either location.
    • The MDD does not have a 128GB drive limit like older Macs. My MDD has 3 drives (a 400GB Hitatchi Deskstar, 40GB Seagate Barracuda 7200.7, and a 30GB Quantum Fireball LCT).
    • Note the ID jumpers on the two drive set. One is set to Master, the other to slave. A single drive can be set to Cable Select.
  11. Start removing the optical drive cage by removing its back cover. Start removing the optical drive cage by removing its back cover.
    • Start removing the optical drive cage by removing its back cover.
  12. Now, remove the IDE and power cables from the drives. Now, remove the IDE and power cables from the drives. Now, remove the IDE and power cables from the drives.
    • Now, remove the IDE and power cables from the drives.
  13. Remove these two Phillips screws: Pull the cage away from the front until it is free. Slide the cage towards you, and out of the Mac.
    • Remove these two Phillips screws:
    • Pull the cage away from the front until it is free.
    • Slide the cage towards you, and out of the Mac.
  14. To remove the drive(s) from the cage, remove the two screws on each side of the drive(s), then pull the drive out of the cage. My MDD has a 3rd party 22X SuperDrive, for burning DVD's in Leopard (Thank You Generic Drive Support!)
    • To remove the drive(s) from the cage, remove the two screws on each side of the drive(s), then pull the drive out of the cage.
    • My MDD has a 3rd party 22X SuperDrive, for burning DVD's in Leopard (Thank You Generic Drive Support!)
Conclusie
16 andere personen hebben deze handleiding voltooid.
Chris Green
34.736 Reputatie
45 handleidingen geschreven
Master Techs Lid van Master Techs
Community
296 Leden
981 handleidingen geschreven
Één commentaar
In the Sacramento FATP factory we used to call this the 'media can' in previous models because there were other drives such as ZIP and JAZZ drives available, until this and the one just prior which only had optical drive options, so it became the 'optical cage'
joey - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 21
Altijd: 11,639
