Ga door naar hoofdinhoud
Power Mac G4 M5183 Logic Board Replacement
Wat je nodig hebt
  1. Power Mac G4 M5183 Logic Board Replacement, Opening PowerMac G4 M5183 Case: stap 1, afbeelding 1 van 2 Power Mac G4 M5183 Logic Board Replacement, Opening PowerMac G4 M5183 Case: stap 1, afbeelding 2 van 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Logic Board Replacement, Heat Sink: stap 2, afbeelding 1 van 2 Power Mac G4 M5183 Logic Board Replacement, Heat Sink: stap 2, afbeelding 2 van 2
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. Power Mac G4 M5183 Logic Board Replacement: stap 3, afbeelding 1 van 1
    • Remove the heat sink by pulling upwards, off of the logic board.
  4. Power Mac G4 M5183 Logic Board Replacement, RAM: stap 4, afbeelding 1 van 2 Power Mac G4 M5183 Logic Board Replacement, RAM: stap 4, afbeelding 2 van 2
    • Locate the RAM modules.
    • Pull side tabs outward. The RAM will pop out of the housing.
  5. Power Mac G4 M5183 Logic Board Replacement, Graphics Card: stap 5, afbeelding 1 van 2 Power Mac G4 M5183 Logic Board Replacement, Graphics Card: stap 5, afbeelding 2 van 2
    • Remove the single screw with the Phillips #1 screwdriver.
    • Pull the graphics card up and out.
  6. Power Mac G4 M5183 Logic Board Replacement, Logic Board: stap 6, afbeelding 1 van 2 Power Mac G4 M5183 Logic Board Replacement, Logic Board: stap 6, afbeelding 2 van 2
    • Remove the six indicated cables attached to the logic board.
    • Use the spudger to remove the modem cable as indicated.
  7. Power Mac G4 M5183 Logic Board Replacement: stap 7, afbeelding 1 van 2 Power Mac G4 M5183 Logic Board Replacement: stap 7, afbeelding 2 van 2
    • Unfasten 3 Phillips screws revealed beneath the heat sink on the CPU board.
    • Carefully remove the CPU board from the Mother Board.
    • Remove the barrell nut screws from the Mother Board which held the CPU board.
    • Unfasten 3 Phillips #1 screws on Mother Board as shown in illustration 1.
    • Slide the logic board about a quarter of an inch to free it from the three retaining pins.
    • Pull upwards and outwards to fully remove the logic board.
  8. Power Mac G4 M5183 Logic Board Replacement: stap 8, afbeelding 1 van 1
    • After removing the (3) #2 philips screws, remove the (4) 1/4" hex nuts, then slide as directed and remove board.
Eindstreep
15 andere personen hebben deze handleiding voltooid.
Justin Petrilli
3.132 Reputatie
11 handleidingen geschreven
Cal Poly, Team 13-24, Maness Winter 2010 Lid van Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Leden
37 handleidingen geschreven
3Gids Commentaar
Are the "hex nuts" under the processor board? Could you provide a close up picture of the "nuts?"
D george - Antwoord
So what is being replaced here? Wouldn’t one have to purchase a new logic board? Any info would be greatly appreciated!
Sandra Cai - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 59
Altijd: 18,707
