Inleiding
This guide will show you how to remove the PowerMac logic board.
Wat je nodig hebt
Pull on outer latch.
Lower door until it is level with your work surface.
Use the spudger to pry the clips horizontally off of the heat sink.
Fully remove the clips by lifting upwards.
Locate the RAM modules.
Pull side tabs outward. The RAM will pop out of the housing.
Remove the single screw with the Phillips #1 screwdriver.
Pull the graphics card up and out.
Remove the six indicated cables attached to the logic board.
Use the spudger to remove the modem cable as indicated.
Unfasten 3 Phillips screws revealed beneath the heat sink on the CPU board.
Carefully remove the CPU board from the Mother Board.
Remove the barrell nut screws from the Mother Board which held the CPU board.
Unfasten 3 Phillips #1 screws on Mother Board as shown in illustration 1.
Slide the logic board about a quarter of an inch to free it from the three retaining pins.
Pull upwards and outwards to fully remove the logic board.
15 andere personen hebben deze handleiding voltooid.
