Inleiding
Installing Modem involves removing the outer case and video card before installation.
Onderdelen
Geen onderdelen nodig.
  1. Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
    • Slowly lift the plate off the cube and disconnect the power cord.
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
    • Remove the screws on the back of the VGA port.
    • Remove the screw attaching the video card to the logic board.
    • Remove power cord from the video card.
    • Remove the power cord.
    • Remove the connector.
    • Remove the video card from the logic board.
    • Carefully lift the video card from the logic board.
    • The video card should come out easily.
    • Separate the video card from the adapter.
    • Remove the two screws from the modem.
    • Lift modem from the Logic Board.
    • The modem should come out easily.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ryan Chun
674 Reputatie
7 handleidingen geschreven
Cal Poly, Team 2-7, Johann Summer 2010 Lid van Cal Poly, Team 2-7, Johann Summer 2010
CPSU-JOHANN-R10S2G7
5 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 5
Altijd: 3,654
