Ga door naar hoofdinhoud
Porter-Cable PC60TAG Motor Brush Replacement
Wat je nodig hebt
  1. Porter-Cable PC60TAG Motor Brush Replacement, Motor Brush: stap 1, afbeelding 1 van 1
    • Using the Phillips #2 screwdriver, remove the 3/4" screw on the back cover.
    • Unplug the grinder before disassembling.
  2. Porter-Cable PC60TAG Motor Brush Replacement: stap 2, afbeelding 1 van 1
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Motor Brush Replacement: stap 3, afbeelding 1 van 1
    • Using the Phillips #2 screwdriver, remove the 1/2" screw holding on the motor brush arm.
  4. Porter-Cable PC60TAG Motor Brush Replacement: stap 4, afbeelding 1 van 1
    • Carefully pull the motor brush arm away from the other device.
  5. Porter-Cable PC60TAG Motor Brush Replacement: stap 5, afbeelding 1 van 1
    • Using the spudger, carefully lift the spring on the motor brush arm off of the motor brush and gently pull it to the side of the motor bush arm.
    • Be careful not to over bend the spring, as this could damage the spring and require replacement.
  6. Porter-Cable PC60TAG Motor Brush Replacement: stap 6, afbeelding 1 van 2 Porter-Cable PC60TAG Motor Brush Replacement: stap 6, afbeelding 2 van 2
    • Using the spudger, gently push the motor brush out of the arm.
  7. Porter-Cable PC60TAG Motor Brush Replacement: stap 7, afbeelding 1 van 1
    • Using a pair of needle nose pliers, gently pull the motor brush terminal off of the motor brush arm.
    • Repeat steps 3-7 on the other side of the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mackenzie Fairbanks
591 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 Lid van UMass Dartmouth, Team 2-2, Isaacson Spring 2016
UMASSD-ISAACSON-S16S2G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 843
