Ga door naar hoofdinhoud
Porter-Cable PC60TAG Motor Assembly Replacement
Wat je nodig hebt
  1. Porter-Cable PC60TAG Motor Assembly Replacement, Motor Assembly: stap 1, afbeelding 1 van 1
    • Using the Phillips #2 screwdriver, remove the 3/4" Phillips screw on the back cover.
  2. Porter-Cable PC60TAG Motor Assembly Replacement: stap 2, afbeelding 1 van 1
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Motor Assembly Replacement: stap 3, afbeelding 1 van 1
    • Using the Phillips #2 screwdriver, remove the1/2" Phillips screw holding on the motor brush arm. Repeat on the other side.
  4. Porter-Cable PC60TAG Motor Assembly Replacement: stap 4, afbeelding 1 van 1
    • Carefully pull the motor brush arm away from the other device, you can leave the wire connected to device. Repeat on the other side.
  5. Porter-Cable PC60TAG Motor Assembly Replacement: stap 5, afbeelding 1 van 1
    • Using the Phillips #2 screwdriver, remove the 1 inch black retainer screw.
  6. Porter-Cable PC60TAG Motor Assembly Replacement: stap 6, afbeelding 1 van 1
    • Using the Phillips #2screwdriver, remove the 4, 1/2" Phillips screws around the head gear.
  7. Porter-Cable PC60TAG Motor Assembly Replacement: stap 7, afbeelding 1 van 1
    • Carefully pull the head gear away from the device, and set aside.
  8. Porter-Cable PC60TAG Motor Assembly Replacement: stap 8, afbeelding 1 van 1
    • Using the Phillips #2 screwdriver, remove the two, 1/2" screws holding the head to the body on the bottom side of the grinder.
  9. Porter-Cable PC60TAG Motor Assembly Replacement: stap 9, afbeelding 1 van 1
    • Using the Phillips #2 screwdriver, remove the other two 1/2" screws holding the head to the body on the top side of the grinder.
  10. Porter-Cable PC60TAG Motor Assembly Replacement: stap 10, afbeelding 1 van 1
    • Holding the head of the device, carefully pull the motor assembly out of the body of the device.
  11. Porter-Cable PC60TAG Motor Assembly Replacement: stap 11, afbeelding 1 van 1
    • Using a 9/16" wrench, loosen the spindle nut inside the head, from the motor assembly.
  12. Porter-Cable PC60TAG Motor Assembly Replacement: stap 12, afbeelding 1 van 1
    • Pull the motor assembly away from the head.
Conclusie
Mackenzie Fairbanks
591 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 Lid van UMass Dartmouth, Team 2-2, Isaacson Spring 2016
UMASSD-ISAACSON-S16S2G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 519
