Ga door naar hoofdinhoud
Porter-Cable 382 Sander Pad Replacement
Wat je nodig hebt
  1. Porter-Cable 382 Sander Pad Replacement, Sander Pad: stap 1, afbeelding 1 van 1
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Sander Pad Replacement: stap 2, afbeelding 1 van 1
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nick O'Sadcia
421 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 8-7, Botvin Spring 2016 Lid van UMass Dartmouth, Team 8-7, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G7
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 1,816
