Ga door naar hoofdinhoud
Porter-Cable 382 On/ Off Switch Replacement
Wat je nodig hebt
  1. Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: stap 1, afbeelding 1 van 2 Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: stap 1, afbeelding 2 van 2
    • First, locate the three screws on the top of the sander.
    • Using a screw driver with a size T20 star bit, unscrew the screws by turning them to the left.
  2. Porter-Cable 382 On/ Off Switch Replacement: stap 2, afbeelding 1 van 2 Porter-Cable 382 On/ Off Switch Replacement: stap 2, afbeelding 2 van 2
    • Locate your on off switch and in order to remove it you must slide it out of its slot.
    • This shouldnt require any special tools, just wiggle the switch up and out.
    • Make sure this is done carefully, the switch is attached to two wires that may break if they are pulled on too hard.
  3. Porter-Cable 382 On/ Off Switch Replacement: stap 3, afbeelding 1 van 1
    • Using a spudger such as the one shown, carefully pry open the connectors as shown just enough to slide the prongs of the switch out.
    • Once both prongs are open, the on-off switch can be removed freely and replaced with a new switch.
Conclusie
Nick O'Sadcia
421 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 8-7, Botvin Spring 2016 Lid van UMass Dartmouth, Team 8-7, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G7
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 244
