Ga door naar hoofdinhoud
Porter-Cable 382 Fan Replacement
Wat je nodig hebt
  1. Porter-Cable 382 Fan Replacement, Sander Pad: stap 1, afbeelding 1 van 1
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Fan Replacement: stap 2, afbeelding 1 van 1
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
  3. Porter-Cable 382 Fan Replacement, Dust Seal/ Break: stap 3, afbeelding 1 van 1
    • Once the sander pad is removed and the sander is exposed locate the white plastic like circular piece surrounding the outside of the sander.
  4. Porter-Cable 382 Fan Replacement: stap 4, afbeelding 1 van 2 Porter-Cable 382 Fan Replacement: stap 4, afbeelding 2 van 2
    • Once you have located the plastic white ring pull up its outer edge as shown. The lip on the inside will bend and be freed from its secured placement.
    • To reassemble, you will have to line up the protruding square with the key slot as shown otherwise your dust seal/ brake will not go back in.
  5. Porter-Cable 382 Fan Replacement, Fan: stap 5, afbeelding 1 van 2 Porter-Cable 382 Fan Replacement, Fan: stap 5, afbeelding 2 van 2
    • Once the dust brake/ seal is removed locate the screw in the center of the device holding down the bearing and fan assembly.
    • unscrew this bolt using a T20 star bit and carefully remove the washer and bearing as shown.
  6. Porter-Cable 382 Fan Replacement: stap 6, afbeelding 1 van 1
    • Next locate the bolts holding down the guard assembly as shown. There will be one bolt on each side, two in total.
    • Using a T15 star bit unscrew these bolts and make sure you keep them in a safe place.
  7. Porter-Cable 382 Fan Replacement: stap 7, afbeelding 1 van 1
    • Once the two screws are removed locate the o-ring that seals the dust collector to its opening.
    • Very delicately pry the o-ring out of its slot using a nylon spudger or plastic opening tool. Then roll it off of the opening as shown.
  8. Porter-Cable 382 Fan Replacement: stap 8, afbeelding 1 van 2 Porter-Cable 382 Fan Replacement: stap 8, afbeelding 2 van 2
    • Now the two guards will come apart as shown, giving you access to the fan.
    • During reassembly, the two guards will line up so that the dust collector opening lines up with the power cord as shown.
  9. Porter-Cable 382 Fan Replacement: stap 9, afbeelding 1 van 1
    • The fan can then simply be pulled from its axle and be replaced with the fan blades facing up.
Conclusie
Nick O'Sadcia
421 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 8-7, Botvin Spring 2016 Lid van UMass Dartmouth, Team 8-7, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G7
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 338
