Inleiding
This guide will require you to first follow the steps to disassemble the sander pad as well as the dust seal/ brake. You will then have to disassemble the outer guard to access the fan in order for it to be replaced.
Wat je nodig hebt
When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
Once the sander is upside down begin by removing your old sandpaper.
Once the sandpaper is removed locate the three screws on your sander pad.
Once the sander pad is removed and the sander is exposed locate the white plastic like circular piece surrounding the outside of the sander.
Once the dust brake/ seal is removed locate the screw in the center of the device holding down the bearing and fan assembly.
unscrew this bolt using a T20 star bit and carefully remove the washer and bearing as shown.
