Wat je nodig hebt
When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
Once the sander is upside down begin by removing your old sandpaper.
Once the sandpaper is removed locate the three screws on your sander pad.
Once the sander pad is removed and the sander is exposed locate the white plastic like circular piece surrounding the outside of the sander.
