Inleiding
Replacing the motherboard will require time and patience, as multiple steps are in this guide. Ensure the laptop is powered off, and be cautious when working around the motherboard, as its cables and plugs are fragile.
Wat je nodig hebt
Flip the laptop over with the screen facing down to reveal the bottom panel.
Unscrew each of the highlighted screws with a Phillips #0 screwdriver.
Use a Phillips #0 screwdriver to remove the two 5 mm screws securing the fan.
Één andere persoon heeft deze handleiding voltooid.
