Ga door naar hoofdinhoud
Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement
Wat je nodig hebt
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Power and Telephone Cords: stap 1, afbeelding 1 van 3 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Power and Telephone Cords: stap 1, afbeelding 2 van 3 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Power and Telephone Cords: stap 1, afbeelding 3 van 3
    • To disconnect the phone cord, squeeze the tab against the connector and pull the cord away from the telephone-line-in-jack.
    • To disconnect the power cord, grasp the end and pull back and away until it is disconnected.
    • Once disconnected remove each cord from its track.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Screws to Base Plate: stap 2, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the six 7mm screws from the base plate.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Remove Bottom Plate from Base: stap 3, afbeelding 1 van 3 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Remove Bottom Plate from Base: stap 3, afbeelding 2 van 3 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Remove Bottom Plate from Base: stap 3, afbeelding 3 van 3
    • With the base turned upside down, grasp the edges of the base plate and gently lift from the rest of the base.
    • Two wires lead from the motherboard to the charger plate, so the two parts cannot be completely separated without further steps.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jay Gunter
378 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 6
Altijd: 372
