Inleiding
Prerequisite Only
Wat je nodig hebt
To disconnect the phone cord, squeeze the tab against the connector and pull the cord away from the telephone-line-in-jack.
To disconnect the power cord, grasp the end and pull back and away until it is disconnected.
Once disconnected remove each cord from its track.
Using a Phillips #00 screwdriver, remove the six 7mm screws from the base plate.
With the base turned upside down, grasp the edges of the base plate and gently lift from the rest of the base.
Één andere persoon heeft deze handleiding voltooid.
