Inleiding
The motherboard for any electronics should only be replaced after all troubleshooting has failed. This is an extremely fragile component and requires patience to remove safely. However, this motherboard was very easy to remove and can be done with only one person though, we recommend asking a friend for help just to be safe.
Wat je nodig hebt
To begin, remove the 8 screws locating on the back of the soundbar. These can be removed with the ifixit screwdriver equipped with a Phillips'head in size J1.
The cover will lift up, but there will be wires underneath connected to the cover that need to be unscrewed.
The 8 screws on the back cover, as well as the screws removed in the following steps, are all the exact same length (approx. 1 centimeter). Keep track of all screws but do not worry if they become mixed up.
11 opmerkingen
Where do you buy the motherboard?
Where do you buy the mother board?
Where do you buy a replacement motherboard? ???
