Ga door naar hoofdinhoud
Polaroid i533 Button Replacement
Wat je nodig hebt
  1. Polaroid i533 Button Replacement, Button: stap 1, afbeelding 1 van 3 Polaroid i533 Button Replacement, Button: stap 1, afbeelding 2 van 3 Polaroid i533 Button Replacement, Button: stap 1, afbeelding 3 van 3
    • Using a #00 screw driver, remove all of the screws on the body of the camera. There are 9 screws total on the face of the camera
    • All of the screws used in the Polaroid i533 are the same size
    • Be sure to not misplace any screws as you will need them to put the camera back together.
  2. Polaroid i533 Button Replacement: stap 2, afbeelding 1 van 2 Polaroid i533 Button Replacement: stap 2, afbeelding 2 van 2
    • Slide open the battery door, then using the plastic opening tool, slightly open the side of the camera case.
    • Gently pull apart the cover from the body of the camera.
    • Do not pull the cover off completely because it is still attached to the logic board.
  3. Polaroid i533 Button Replacement: stap 3, afbeelding 1 van 3 Polaroid i533 Button Replacement: stap 3, afbeelding 2 van 3 Polaroid i533 Button Replacement: stap 3, afbeelding 3 van 3
    • Locate the black tab where the LCD screen ribbon is attached to the logic board.
    • Using the plastic opening tool, flip the black tab towards the ribbon.
    • Gently pull the ribbon away from the logic board.
  4. Polaroid i533 Button Replacement: stap 4, afbeelding 1 van 1
    • The back half of the camera with the LCD screen should now be separated from the front casing.
    • If you are experiencing problems with your menu buttons, you must replace the entire back half of the outer case (Not including the screen). move on to step 5.
    • If you are experiencing problems only with your snap button (the one that you push to take pictures), skip ahead to step 7.
  5. Polaroid i533 Button Replacement: stap 5, afbeelding 1 van 1
    • Using a #00 screwdriver, remove the four screws located at each corner of the LCD screen.
  6. Polaroid i533 Button Replacement: stap 6, afbeelding 1 van 1
    • Remove the LCD screen from the old casing.
    • attach the LCD screen to the new casing using the screws removed in step 5.
  7. Polaroid i533 Button Replacement: stap 7, afbeelding 1 van 2 Polaroid i533 Button Replacement: stap 7, afbeelding 2 van 2
    • Using a #00 screw driver, remove the screw on the bottom of the logic board just above the tripod attachment.
    • Gently pull the front of the case away from the insides of the camera.
  8. Polaroid i533 Button Replacement: stap 8, afbeelding 1 van 2 Polaroid i533 Button Replacement: stap 8, afbeelding 2 van 2
    • Locate the button that will be removed.
    • To remove: gently push outward on the button from the inside of the casing.
  9. Polaroid i533 Button Replacement: stap 9, afbeelding 1 van 1
    • Remove spring from bottom of broken button.
    • Remove and replace defective button.
    • Do not lose spring as it is needed for replacement button.
Conclusie
Terichael Office
9 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-4, Johann Summer 2010 Lid van Cal Poly, Team 3-4, Johann Summer 2010
CPSU-JOHANN-R10S3G4
4 Leden
9 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 38
Altijd: 2,649
