Ga door naar hoofdinhoud
Polaroid Z2300 Battery Replacement
  1. Polaroid Z2300 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Polaroid Z2300 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the camera upside down and gently use your thumb to pull the hatch forward and then upwards.
    • Once you lift the hatch up you will see the battery.
  2. Polaroid Z2300 Battery Replacement: stap 2, afbeelding 1 van 2 Polaroid Z2300 Battery Replacement: stap 2, afbeelding 2 van 2
    • Once you see the battery, you will see a tab saying 'pull' attached to the battery. gently pull on it until the battery is removed from the camera.
    • You can pull the battery easily afterwards.
  3. Polaroid Z2300 Battery Replacement: stap 3, afbeelding 1 van 1
    • Afterwards, you can easily reattach the battery back.
Conclusie
Jasem Almeeli
101 Reputatie
1 Handleiding geschreven
USF Tampa, Team S13-G1, Cagle Spring 2017 Lid van USF Tampa, Team S13-G1, Cagle Spring 2017
USFT-CAGLE-S17S13G1
4 Leden
2 handleidingen geschreven
Één opmerking
Do you know where to find a replacement battery? I’ve looked all over the internet.
Wendy Ralph - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 48
Altijd: 3,883
