Inleiding
Replacing a broken or scratched lens on a Polaroid Sun 600 LMS.
  1. Move film door slide on the left side of camera forward. Pull film door open.
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
  2. Open the flash assembly by holding the sides of the top piece of the camera and pushing up gently until it snaps into place. If your camera is old or dirty, it may take more force to open the flash assembly.
    • Open the flash assembly by holding the sides of the top piece of the camera and pushing up gently until it snaps into place.
    • If your camera is old or dirty, it may take more force to open the flash assembly.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Use a spudger on each side to separate the flash segment from the main body. Be careful not to do this too hard because you may pull out the connecting wires.
    • Use a spudger on each side to separate the flash segment from the main body.
    • Be careful not to do this too hard because you may pull out the connecting wires.
  5. Use several plastic opening tools around the edges of the camera's body to separate it from the plastic frame. Use several plastic opening tools around the edges of the camera's body to separate it from the plastic frame.
    • Use several plastic opening tools around the edges of the camera's body to separate it from the plastic frame.
  6. Place left hand on the gray section and right hand on the black section. Pull the sections apart.
    • Place left hand on the gray section and right hand on the black section.
    • Pull the sections apart.
  7. Carefully remove the damaged lens from the interior of the camera. Replace with a new lens.
    • Carefully remove the damaged lens from the interior of the camera.
    • Replace with a new lens.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ian Hosek
345 Reputatie
1 Handleiding geschreven
Cal Poly, Team 3-18, Maness Winter 2010 Lid van Cal Poly, Team 3-18, Maness Winter 2010
CPSU-MANESS-W10S3G18
4 Leden
4 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 4
Afgelopen 7 Dagen: 10
Afgelopen 30 Dagen: 27
Altijd: 7,923
