Ga door naar hoofdinhoud
Polaroid SNAP View Finder Replacement
Wat je nodig hebt
  1. Polaroid SNAP View Finder Replacement, Polaroid SNAP Front and Back Face Plate Removal: stap 1, afbeelding 1 van 1
    • Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Screw head: Phillips, Screw length: 3mm
  2. Polaroid SNAP View Finder Replacement: stap 2, afbeelding 1 van 2 Polaroid SNAP View Finder Replacement: stap 2, afbeelding 2 van 2
    • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
    • Then it should be easy to simply lift the rear face plate up and remove it.
  3. Polaroid SNAP View Finder Replacement: stap 3, afbeelding 1 van 2 Polaroid SNAP View Finder Replacement: stap 3, afbeelding 2 van 2
    • Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove.
    • Screw head: Philips, Screw length: 5mm
  4. Polaroid SNAP View Finder Replacement: stap 4, afbeelding 1 van 3 Polaroid SNAP View Finder Replacement: stap 4, afbeelding 2 van 3 Polaroid SNAP View Finder Replacement: stap 4, afbeelding 3 van 3
    • Once the screws are removed, flip the camera over
    • Use a plastic opening tool to disengage the six clips until the front face plate can be removed safely
  5. Polaroid SNAP View Finder Replacement: stap 5, afbeelding 1 van 1
    • The cameras innards should now be accessible to you
  6. Polaroid SNAP View Finder Replacement, View Finder: stap 6, afbeelding 1 van 2 Polaroid SNAP View Finder Replacement, View Finder: stap 6, afbeelding 2 van 2
    • Gently grasp the view finder (while in the closed position) with your thumb and fore finger. Then carefully pull the viewfinder outwards.
  7. Polaroid SNAP View Finder Replacement: stap 7, afbeelding 1 van 2 Polaroid SNAP View Finder Replacement: stap 7, afbeelding 2 van 2
    • Once the view finder is out, a small black tab should come loose from the viewfinder. Insert this small black tab in to the hole on the side of the new view finder, with the round side up.
Conclusie
Austin Broyles
249 Reputatie
2 handleidingen geschreven
USF Tampa, Team 7-3, Cheng Spring 2016 Lid van USF Tampa, Team 7-3, Cheng Spring 2016
USFT-CHENG-S16S7G3
4 Leden
18 handleidingen geschreven
Één opmerking
Where can I buy a replacement viewfinder for this camera?
Shelby Sisk - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 3,466
