Ga door naar hoofdinhoud
Polaroid S7 Battery Replacement
Wat je nodig hebt
  1. Polaroid S7 Battery Replacement, Remove the back: stap 1, afbeelding 1 van 2 Polaroid S7 Battery Replacement, Remove the back: stap 1, afbeelding 2 van 2
    • Insert the flat end of a soft plastic opening tool between the screen and the back cover.
    • Pry the two pieces apart.
    • Take care not to rip the ribbons that connect the screen to the back cover.
  2. Polaroid S7 Battery Replacement: stap 2, afbeelding 1 van 1
    • Use a metal spudger to remove the orange sticker.
  3. Polaroid S7 Battery Replacement: stap 3, afbeelding 1 van 1
    • Use the screwdriver to remove the 2 x 4 mm Phillips #00 head screws from the blue board located on the lower-right corner of the battery.
  4. Polaroid S7 Battery Replacement: stap 4, afbeelding 1 van 2 Polaroid S7 Battery Replacement: stap 4, afbeelding 2 van 2
    • Use the metal spudger to remove the three pieces of clear tape adhering from the battery to the blue board.
    • Pry the battery up from the right side.
  5. Polaroid S7 Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the yellow plastic that covers the battery connector.
  6. Polaroid S7 Battery Replacement: stap 6, afbeelding 1 van 1
    • Use a soldering iron to remove the wires connected to the battery.
Conclusie
Anthony Larratt
269 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-2, Blackwell Winter 2015 Lid van USF Tampa, Team 1-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G2
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 3,249
