Ga door naar hoofdinhoud
Polaroid S10 Speaker Replacement
Wat je nodig hebt
  1. Polaroid S10 Speaker Replacement, Removing the backcover: stap 1, afbeelding 1 van 3 Polaroid S10 Speaker Replacement, Removing the backcover: stap 1, afbeelding 2 van 3 Polaroid S10 Speaker Replacement, Removing the backcover: stap 1, afbeelding 3 van 3
    • Place an opening pick between the volume button and the back cover.
    • More than one pick may be needed, but avoid placing more than two picks in the same space.
    • Excessive force on the pick will break the volume button.
    • Carefully remove the back cover using the metal spudger.
    • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
  2. Polaroid S10 Speaker Replacement, Speaker Assembly: stap 2, afbeelding 1 van 2 Polaroid S10 Speaker Replacement, Speaker Assembly: stap 2, afbeelding 2 van 2
    • Use a heavy-duty nylon spudger to remove the tape.
    • Unscrew the four 5 mm screws with the J000 screwdriver that connects the speakers.
  3. Polaroid S10 Speaker Replacement, Desoldering the Speakers: stap 3, afbeelding 1 van 2 Polaroid S10 Speaker Replacement, Desoldering the Speakers: stap 3, afbeelding 2 van 2
    • Carefully desolder the 4 connections of the speakers.
    • Do not touch the soldering iron to the motherboard or LCD screen.
Conclusie
James
367 Reputatie
3 handleidingen geschreven
Colorado Springs, Team 1-4, May Spring 2015 Lid van Colorado Springs, Team 1-4, May Spring 2015
UCCS-MAY-S15S1G4
4 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 14
Altijd: 361
