Ga door naar hoofdinhoud
Polaroid S10 Battery Replacement
Wat je nodig hebt
  1. Polaroid S10 Battery Replacement, Removing the backcover: stap 1, afbeelding 1 van 3 Polaroid S10 Battery Replacement, Removing the backcover: stap 1, afbeelding 2 van 3 Polaroid S10 Battery Replacement, Removing the backcover: stap 1, afbeelding 3 van 3
    • Place an opening pick between the volume button and the back cover.
    • More than one pick may be needed, but avoid placing more than two picks in the same space.
    • Excessive force on the pick will break the volume button.
    • Carefully remove the back cover using the metal spudger.
    • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
  2. Polaroid S10 Battery Replacement, Battery: stap 2, afbeelding 1 van 3 Polaroid S10 Battery Replacement, Battery: stap 2, afbeelding 2 van 3 Polaroid S10 Battery Replacement, Battery: stap 2, afbeelding 3 van 3
    • Use a spudger to carefully remove the tape nearest to the battery.
    • Use caution while removing tape. Too much force can damage the device.
    • Gently use the spudger to remove the battery out of place by wedging it out from the bottom.
    • Do not move the battery. Moving it could cause the cables to be ripped out.
  3. Polaroid S10 Battery Replacement, Battery Connection: stap 3, afbeelding 1 van 2 Polaroid S10 Battery Replacement, Battery Connection: stap 3, afbeelding 2 van 2
    • Carefully desolder the 2 wires that connect the battery to the motherboard.
    • Do not touch the soldering iron to the motherboard or the LCD screen.
Conclusie
Follow these instructions to reassemble your device.
Één andere persoon heeft deze handleiding voltooid.
James
367 Reputatie
3 handleidingen geschreven
Colorado Springs, Team 1-4, May Spring 2015 Lid van Colorado Springs, Team 1-4, May Spring 2015
UCCS-MAY-S15S1G4
4 Leden
13 handleidingen geschreven
Één opmerking
Can't open the %#*@ thing!!!!!!!!!!
tosaguys - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 5,206
