Inleiding
If the screen fails to display properly, consider using this guide to replace it.
Wat je nodig hebt
Flip the device so that the screen faces down, with the back facing up.
Unscrew the four screws with a PH000 screwdriver.
Set the top panel down so that the interior faces up, and the exterior of the screen faces down.
Using the Opening Tool, gently lift up each of the snaps to release the screen from the panel.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
In terms of removing the screen, we found the plastic opening tool didn't help to lift the snaps to release the screen from the panel. It worked better when we used our hands to snap it out.
