Ga door naar hoofdinhoud
Polaroid Onestep Close Up Primary Lens Replacement
Wat je nodig hebt
  1. Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: stap 1, afbeelding 1 van 3 Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: stap 1, afbeelding 2 van 3 Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: stap 1, afbeelding 3 van 3
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Primary Lens Replacement, Opening Film Tray: stap 2, afbeelding 1 van 2 Polaroid Onestep Close Up Primary Lens Replacement, Opening Film Tray: stap 2, afbeelding 2 van 2
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: stap 3, afbeelding 1 van 3 Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: stap 3, afbeelding 2 van 3 Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: stap 3, afbeelding 3 van 3
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Primary Lens Replacement, Primary Lens: stap 4, afbeelding 1 van 1
    • Once the front assembly is removed, the primary lens should be exposed without any trouble.
  5. Polaroid Onestep Close Up Primary Lens Replacement, Removal of primary lens: stap 5, afbeelding 1 van 2 Polaroid Onestep Close Up Primary Lens Replacement, Removal of primary lens: stap 5, afbeelding 2 van 2
    • Use your spudger to leverage the lens from the groove at the top (red).
    • Pry the lens loose. It may pop out, so have a method in place to prevent it from dropping.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Christopher Collazo
318 Reputatie
2 handleidingen geschreven
USF Tampa, Team 3-5, Brown Fall 2014 Lid van USF Tampa, Team 3-5, Brown Fall 2014
USFT-BROWN-F14S3G5
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 1,483
