Ga door naar hoofdinhoud
Polaroid One-Step 600 Battery Cartridge Replacement
  1. Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: stap 1, afbeelding 1 van 3 Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: stap 1, afbeelding 2 van 3 Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: stap 1, afbeelding 3 van 3
    • Open the bottom compartment of the camera by sliding the lever towards the opening.
  2. Polaroid One-Step 600 Battery Cartridge Replacement: stap 2, afbeelding 1 van 1
    • Remove old battery/ film cartridge from camera.
  3. Polaroid One-Step 600 Battery Cartridge Replacement: stap 3, afbeelding 1 van 1
    • Follow the instructions that came with the new battery/ film cartridge to insert the new cartridge into the camera.
    • Close the battery compartment of the camera.
    • Note: The camera in this picture does not contain a battery.
Eindstreep
13 andere personen hebben deze handleiding voltooid.
Doug Jimenez
538 Reputatie
2 handleidingen geschreven
Cal Poly, Team 16-31, Maness Winter 2010 Lid van Cal Poly, Team 16-31, Maness Winter 2010
CPSU-MANESS-W10S16G31
4 Leden
6 handleidingen geschreven
14 opmerkingen
It worked but its expensive
Jessica diaz - Antwoord
I put new film in, it´s turning on, the flash is going off, but no film is coming out after the flash. What is the problem?
tristanmoeller2013 - Antwoord
nothing happened
new film installed
no sound
no flash
no action
eminickstone - Antwoord
I'm having the same issue
Marie -
I'm having same issue.
Marie -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 81
Afgelopen 30 dagen: 398
Altijd: 150,219
