Ga door naar hoofdinhoud
Polaroid Cube Video Quality Switch Replacement
Wat je nodig hebt
  1. Polaroid Cube Video Quality Switch Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
  2. Polaroid Cube Video Quality Switch Replacement: stap 2, afbeelding 1 van 1
    • Use the Plastic Opening tool to pry off and remove the front cover.
  3. Polaroid Cube Video Quality Switch Replacement: stap 3, afbeelding 1 van 1
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
  4. Polaroid Cube Video Quality Switch Replacement: stap 4, afbeelding 1 van 2 Polaroid Cube Video Quality Switch Replacement: stap 4, afbeelding 2 van 2
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
  5. Polaroid Cube Video Quality Switch Replacement: stap 5, afbeelding 1 van 1
    • Remove shell from top and bottom of camera.
  6. Polaroid Cube Video Quality Switch Replacement: stap 6, afbeelding 1 van 1
    • Remove the rubber seal wrapped around the camera.
  7. Polaroid Cube Video Quality Switch Replacement: stap 7, afbeelding 1 van 2 Polaroid Cube Video Quality Switch Replacement: stap 7, afbeelding 2 van 2
    • Remove the tape wrapped around the battery.
  8. Polaroid Cube Video Quality Switch Replacement: stap 8, afbeelding 1 van 3 Polaroid Cube Video Quality Switch Replacement: stap 8, afbeelding 2 van 3 Polaroid Cube Video Quality Switch Replacement: stap 8, afbeelding 3 van 3
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
  9. Polaroid Cube Video Quality Switch Replacement: stap 9, afbeelding 1 van 2 Polaroid Cube Video Quality Switch Replacement: stap 9, afbeelding 2 van 2
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
  10. Polaroid Cube Video Quality Switch Replacement: stap 10, afbeelding 1 van 1
    • Gently remove the battery pin connector from the circuit board.
  11. Polaroid Cube Video Quality Switch Replacement, Video Quality Switch: stap 11, afbeelding 1 van 2 Polaroid Cube Video Quality Switch Replacement, Video Quality Switch: stap 11, afbeelding 2 van 2
    • Using a J00 head screwdriver, unscrew the 3.46mm screw that connects the top circuit board to the video quality switch board.
  12. Polaroid Cube Video Quality Switch Replacement: stap 12, afbeelding 1 van 1
    • Remove the circuit board.
  13. Polaroid Cube Video Quality Switch Replacement: stap 13, afbeelding 1 van 2 Polaroid Cube Video Quality Switch Replacement: stap 13, afbeelding 2 van 2
    • Using a J00 head screwdriver, unscrew the two 3.46mm screws connecting the video quality switch to the case.
    • Remove and replace the broken video quality switch.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Grant Baldwin
685 Reputatie
2 handleidingen geschreven
IUPUI, Team 3-2, Harley Fall 2016 Lid van IUPUI, Team 3-2, Harley Fall 2016
IUPUI-HARLEY-F16S3G2
4 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 862
