Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Use this guide to replace the speakers on your Polaroid A10.
  1. Begin by having the side with volume and power button face up towards you. Insert a plastic opening tool between the display and the back cover. Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. The speakers are located on the bottom of the device, below the battery and adjacent to the motherboard.
    • The speakers are located on the bottom of the device, below the battery and adjacent to the motherboard.
  3. OPEN ALLE TABBLADEN
    RAM-upgradekits voor Mac
    Koop kits
    Genoeg RAM
    voor al je tabbladen
    Koop kits
  4. Using the Phillips #000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise. Carefully remove the speakers from original position without  pulling out the wires. Carefully remove the speakers from original position without  pulling out the wires.
    • Using the Phillips #000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
    • Carefully remove the speakers from original position without pulling out the wires.
  5. Using the soldering tool, remove the two small black wires  and two small red wires from the motherboard.
    • Using the soldering tool, remove the two small black wires and two small red wires from the motherboard.
    • The wire connections are located on the motherboard next to the corner of the battery closest to the motherboard.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  6. Gently lift the speakers up and out of the device.
    • Gently lift the speakers up and out of the device.
Conclusie
Koby
104 Reputatie
1 Handleiding geschreven
UW Tacoma, Team 3-3, Rose Winter 2015 Lid van UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 Leden
12 handleidingen geschreven
This is not what I meant I wanted to know what to do if the wires came out of the
amirahoresanwo - Antwoord
If the wires and out of the
Speaker right
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 160
