Ga door naar hoofdinhoud
Polaroid A10 Front/Back Camera Replacement
Wat je nodig hebt
  1. Polaroid A10 Front/Back Camera Replacement, Back Cover: stap 1, afbeelding 1 van 3 Polaroid A10 Front/Back Camera Replacement, Back Cover: stap 1, afbeelding 2 van 3 Polaroid A10 Front/Back Camera Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Front/Back Camera Replacement, Battery: stap 2, afbeelding 1 van 3 Polaroid A10 Front/Back Camera Replacement, Battery: stap 2, afbeelding 2 van 3 Polaroid A10 Front/Back Camera Replacement, Battery: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    Koop
    • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
    • It is better to use a plastic card if you have one.
    • Gently lift up the battery as you continue to separate the glue from the battery.
    • Lift up just enough to see where the glue is, so that you don't bend the battery.
    • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
  3. Polaroid A10 Front/Back Camera Replacement: stap 3, afbeelding 1 van 3 Polaroid A10 Front/Back Camera Replacement: stap 3, afbeelding 2 van 3 Polaroid A10 Front/Back Camera Replacement: stap 3, afbeelding 3 van 3
  4. Polaroid A10 Front/Back Camera Replacement: stap 4, afbeelding 1 van 1
    • Gently lift the battery up and out of the device.
  5. Polaroid A10 Front/Back Camera Replacement, Front/Back Camera: stap 5, afbeelding 1 van 1
    • The camera head is located on the upper middle section of the device, close to the battery.
  6. Polaroid A10 Front/Back Camera Replacement: stap 6, afbeelding 1 van 2 Polaroid A10 Front/Back Camera Replacement: stap 6, afbeelding 2 van 2
    • Start by locating the two left and right screws which hold the camera head in place.
    • Using the Phillip's 000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
  7. Polaroid A10 Front/Back Camera Replacement: stap 7, afbeelding 1 van 3 Polaroid A10 Front/Back Camera Replacement: stap 7, afbeelding 2 van 3 Polaroid A10 Front/Back Camera Replacement: stap 7, afbeelding 3 van 3
    • Locate the camera ribbon cable that is connected to the motherboard.
    • With a spudger, remove the camera ribbon cable base from the motherboard connector.
    • With one finger, delicately remove the camera ribbon cable by sliding down.
Conclusie
Shilpa Verma
353 Reputatie
3 handleidingen geschreven
UW Tacoma, Team 3-3, Rose Winter 2015 Lid van UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 204
