Ga door naar hoofdinhoud
Polar V800 Charging Port Cover Replacement
Wat je nodig hebt
  1. Polar V800 Charging Port Cover Replacement, Watch Band: stap 1, afbeelding 1 van 3 Polar V800 Charging Port Cover Replacement, Watch Band: stap 1, afbeelding 2 van 3 Polar V800 Charging Port Cover Replacement, Watch Band: stap 1, afbeelding 3 van 3
    • Using a narrow object like a paperclip, push the pins located in the watch band in the direction of the arrow indicated on the watch.
    • Completely pull out the pins.
    • It isn't necessary to remove the watch band before replacing other parts of the watch, but it may make removal of other elements of the watch more accessible and clear.
    • When replacing the charging port cover, only take out the pin that is closest to the charging port cover.
  2. Polar V800 Charging Port Cover Replacement: stap 2, afbeelding 1 van 3 Polar V800 Charging Port Cover Replacement: stap 2, afbeelding 2 van 3 Polar V800 Charging Port Cover Replacement: stap 2, afbeelding 3 van 3
    • To remove the watch band, pull each end of the watch band away from the watch frame.
  3. Polar V800 Charging Port Cover Replacement, Charging Port Cover: stap 3, afbeelding 1 van 3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: stap 3, afbeelding 2 van 3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: stap 3, afbeelding 3 van 3
    • Take off the charging port cover.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nick B.
387 Reputatie
1 Handleiding geschreven
Cal Poly, Team S17-G6, Livingston Spring 2018 Lid van Cal Poly, Team S17-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G6
4 Leden
8 handleidingen geschreven
Één opmerking
where does not procure the battery port cover ?
Chenthill P - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 2,944
