Ga door naar hoofdinhoud
Polar M400 Watch Screen Replacement
Wat je nodig hebt
  1. Polar M400 Watch Screen Replacement, Wrist Strap: stap 1, afbeelding 1 van 1
    • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
  2. Polar M400 Watch Screen Replacement: stap 2, afbeelding 1 van 2 Polar M400 Watch Screen Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Apply an upward pressure to the holes until the locking pins release.
    • Use precision tweezers to remove the pins that connect the face with the strap.
  3. Polar M400 Watch Screen Replacement: stap 3, afbeelding 1 van 1
    • Once the pins are released, the old wrist strap should snap off.
    • Simply lock the new wrist strap into place.
  4. Polar M400 Watch Screen Replacement, Battery: stap 4, afbeelding 1 van 1
    • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
  5. Polar M400 Watch Screen Replacement: stap 5, afbeelding 1 van 2 Polar M400 Watch Screen Replacement: stap 5, afbeelding 2 van 2
    • Gently remove the backing from the watch.
  6. Polar M400 Watch Screen Replacement: stap 6, afbeelding 1 van 2 Polar M400 Watch Screen Replacement: stap 6, afbeelding 2 van 2
    Koop
    • Use tweezers to gently pry the golden sensor away from the battery.
    • Remove battery using the plastic opening tools.
  7. Polar M400 Watch Screen Replacement, Screen: stap 7, afbeelding 1 van 2 Polar M400 Watch Screen Replacement, Screen: stap 7, afbeelding 2 van 2
    • Detach the screen from the screen protector using a PH000 screwdriver.
  8. Polar M400 Watch Screen Replacement: stap 8, afbeelding 1 van 2 Polar M400 Watch Screen Replacement: stap 8, afbeelding 2 van 2
    • Attach a new screen to the screen protector.
    • Make sure that the charging port remains accessible, as it can easily become detached during the replacement.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Nicholas Sanders
513 Reputatie
2 handleidingen geschreven
10 opmerkingen
Hi, where can i buy the replacement?
Thanks
Mario Sánchez-Barriga Marín - Antwoord
hi,where can I buy the usb replacement.
GamesFISH_1989 - Antwoord
Hi, were can i buy the replacement. Thanks
Julien Genon - Antwoord
https://www.allsystem.cz/
I bought a connector USB there… Maybe can be interesting for someone else…
manuel caudera - Antwoord
hello manuel,
i tried to order from the web site you specified, but it looks like they are not delivering in france,
cna you please tell me where else i can order this peice
Mathieu Poncet -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 64
Altijd: 9,057
