Ga door naar hoofdinhoud
Poin2 Chromebook 11 Charging Port Replacement
Wat je nodig hebt
  1. Poin2 Chromebook 11 Charging Port Replacement, Battery: stap 1, afbeelding 1 van 2 Poin2 Chromebook 11 Charging Port Replacement, Battery: stap 1, afbeelding 2 van 2
    • Power down the Poin2 Chromebook 11 and disconnect the power adapter.
    • Close the Chromebook and position it with the base facing up.
    • Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
    • Poin2 Chromebook 11 does not have screws under its rubber feet at the base.
  2. Poin2 Chromebook 11 Charging Port Replacement: stap 2, afbeelding 1 van 3 Poin2 Chromebook 11 Charging Port Replacement: stap 2, afbeelding 2 van 3 Poin2 Chromebook 11 Charging Port Replacement: stap 2, afbeelding 3 van 3
    • Insert a 1cm-wide plastic opening tool between the base and top frame.
    • Applying pressure up and down with the tool may be necessary. When you hear a "click," this indicates the separation of the frame.
    • Pry (up and down) around the entire border of the Chromebook to separate.
    • Use your hands to gently lift the base away from the frame.
  3. Poin2 Chromebook 11 Charging Port Replacement: stap 3, afbeelding 1 van 3 Poin2 Chromebook 11 Charging Port Replacement: stap 3, afbeelding 2 van 3 Poin2 Chromebook 11 Charging Port Replacement: stap 3, afbeelding 3 van 3
    • Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
    • The connector is a tight fit and requires careful pressure for release.
  4. Poin2 Chromebook 11 Charging Port Replacement: stap 4, afbeelding 1 van 2 Poin2 Chromebook 11 Charging Port Replacement: stap 4, afbeelding 2 van 2
    • Remove the six 4mm screws using a Phillips #0 screwdriver.
  5. Poin2 Chromebook 11 Charging Port Replacement: stap 5, afbeelding 1 van 1
    • Lift the battery from the frame.
  6. Poin2 Chromebook 11 Charging Port Replacement, Charging Port: stap 6, afbeelding 1 van 2 Poin2 Chromebook 11 Charging Port Replacement, Charging Port: stap 6, afbeelding 2 van 2
    • The changing port is located on the upper-right corner of the computer.
    • Disconnect the charging port from the motherboard using a spudger to push the 4-wire connector out from the port.
  7. Poin2 Chromebook 11 Charging Port Replacement: stap 7, afbeelding 1 van 2 Poin2 Chromebook 11 Charging Port Replacement: stap 7, afbeelding 2 van 2
    • Remove silver tape covering hinge.
  8. Poin2 Chromebook 11 Charging Port Replacement: stap 8, afbeelding 1 van 2 Poin2 Chromebook 11 Charging Port Replacement: stap 8, afbeelding 2 van 2
    • The metal hinge at the top right corner must be lifted to access the charging port.
    • Use a Phillips #0 screwdriver and remove the two 7mm screws from the hinge.
  9. Poin2 Chromebook 11 Charging Port Replacement: stap 9, afbeelding 1 van 1
    • Pry the metal hinge up, until it sits perpendicular to the motherboard.
    • The metal hinge is a tight fit and requires careful strength when lifting.
  10. Poin2 Chromebook 11 Charging Port Replacement: stap 10, afbeelding 1 van 2 Poin2 Chromebook 11 Charging Port Replacement: stap 10, afbeelding 2 van 2
    • Use tweezers to gently pull the charging port out of the frame.
Conclusie
4 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Great, Now where can I find this part to fix my laptop???
marrowii - Antwoord
where do I buy the new port???
rhena9 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 6,870
