Ga door naar hoofdinhoud
Pocket Knife Wooden Casing Replacement
Wat je nodig hebt
  1. Pocket Knife Wooden Casing Replacement, Wooden Casing: stap 1, afbeelding 1 van 2 Pocket Knife Wooden Casing Replacement, Wooden Casing: stap 1, afbeelding 2 van 2
    • Trace the knife outline onto wood.
  2. Pocket Knife Wooden Casing Replacement: stap 2, afbeelding 1 van 2 Pocket Knife Wooden Casing Replacement: stap 2, afbeelding 2 van 2
    • Cut out the outline of the wood.
    • Cut the height of the wood to the correct measurement.
  3. Pocket Knife Wooden Casing Replacement: stap 3, afbeelding 1 van 2 Pocket Knife Wooden Casing Replacement: stap 3, afbeelding 2 van 2
    • Sand the wood so that it is smooth and free of hard edges.
    • For the best result, sand in the direction of the grain as much as possible.
  4. Pocket Knife Wooden Casing Replacement: stap 4, afbeelding 1 van 3 Pocket Knife Wooden Casing Replacement: stap 4, afbeelding 2 van 3 Pocket Knife Wooden Casing Replacement: stap 4, afbeelding 3 van 3
    • Stain and polish the wood so that it is reflects the other side of the knife.
    • Apply another coat after the first coat dries if you want a darker stain.
    • If you get the Stain and Polish on your skin, your skin might be stained for a few days. In this case, make sure you wash thoroughly; Stain and Polish is only toxic if it is ingested.
  5. Pocket Knife Wooden Casing Replacement: stap 5, afbeelding 1 van 2 Pocket Knife Wooden Casing Replacement: stap 5, afbeelding 2 van 2
    • Drill four small holes that will go over the extruded parts of the knife.
    • You can accurately mark the positions of the holes by coloring the screw heads with sharpie then stamping them into the wood.
  6. Pocket Knife Wooden Casing Replacement: stap 6, afbeelding 1 van 3 Pocket Knife Wooden Casing Replacement: stap 6, afbeelding 2 van 3 Pocket Knife Wooden Casing Replacement: stap 6, afbeelding 3 van 3
    • Glue the wood to the knife and clean any hard edges or excess glue that comes from this step.
Eindstreep
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 384
