Ga door naar hoofdinhoud
Plum Optimax 10 Display Replacement
Wat je nodig hebt
  1. Plum Optimax 10 Display Replacement, Back Cover: stap 1, afbeelding 1 van 2 Plum Optimax 10 Display Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
  2. Plum Optimax 10 Display Replacement: stap 2, afbeelding 1 van 2 Plum Optimax 10 Display Replacement: stap 2, afbeelding 2 van 2
    • Use a metal spudger to begin lifting the back cover.
    • Then, create leverage and gently remove the entire cover.
  3. Plum Optimax 10 Display Replacement, Motherboard: stap 3, afbeelding 1 van 2 Plum Optimax 10 Display Replacement, Motherboard: stap 3, afbeelding 2 van 2
    • Use flathead screwdriver tool to remove the three 2.5 mm screws shown in the photo. Two screws are located at the base of the motherboard and there is one screw located at the top.
  4. Plum Optimax 10 Display Replacement: stap 4, afbeelding 1 van 1
    • Once screws are removed, carefully remove the motherboard out of encasing.
  5. Plum Optimax 10 Display Replacement, Battery: stap 5, afbeelding 1 van 2 Plum Optimax 10 Display Replacement, Battery: stap 5, afbeelding 2 van 2
    • Remove electrical tape placed around the battery to keep it in place.
  6. Plum Optimax 10 Display Replacement: stap 6, afbeelding 1 van 2 Plum Optimax 10 Display Replacement: stap 6, afbeelding 2 van 2
    • Use the spudger as a wedge underneath the battery to assist in removal.
    • Once loosened with the spudger, the battery is now removed from the device.
    • Always use a plastic opening tool or nylon spudger to remove batteries. Metal tools can puncture a battery and potentially catch on fire.
  7. Plum Optimax 10 Display Replacement, Display: stap 7, afbeelding 1 van 1
    • Gently pop the display out from the display cover by prying around the edges with a plastic opening tool or spudger.
    • The display is held in by about 4-5 clamps on each side.
    • Be careful not to crack or damage the glass display.
    • Using a metal spudger as shown in the photo has a higher chance of damaging the device. Use an ESD safe tool instead.
  8. Plum Optimax 10 Display Replacement: stap 8, afbeelding 1 van 2 Plum Optimax 10 Display Replacement: stap 8, afbeelding 2 van 2
    • Insert the new display in and clamp it back into the original spot.
    • Ensure that the display is in the correct spot where the ribbon cables are able to connect it to the motherboard.
    • Make sure the display snaps back into place. Listen for "popping," and press firmly until no more sounds are made.
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 234
