Ga door naar hoofdinhoud
Playstation Classic Motherboard Replacement
Wat je nodig hebt
  1. Playstation Classic Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Flip the console so its back is facing up.
  2. Playstation Classic Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the five 3mm screws using the Phillips #00 screwdriver.
    • Make sure to keep your screws together in a secure location to avoid misplacement.
  3. Playstation Classic Motherboard Replacement: stap 3, afbeelding 1 van 3 Playstation Classic Motherboard Replacement: stap 3, afbeelding 2 van 3 Playstation Classic Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Remove the back plate from the rest of the console using your hands or the Jimmy tool.
  4. Playstation Classic Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the motherboard's five 3mm screws with the Phillips #00 screwdriver.
    • Be careful not to apply too much force. The motherboard is flimsy and easy to break.
    • Keep track of your screws once they are removed.
  5. Playstation Classic Motherboard Replacement: stap 5, afbeelding 1 van 3 Playstation Classic Motherboard Replacement: stap 5, afbeelding 2 van 3 Playstation Classic Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
  6. Playstation Classic Motherboard Replacement: stap 6, afbeelding 1 van 3 Playstation Classic Motherboard Replacement: stap 6, afbeelding 2 van 3 Playstation Classic Motherboard Replacement: stap 6, afbeelding 3 van 3
    • The motherboard is connected to its metal protective casing with sticky pads. No tools are required to remove it.
    • Pull the metal casing off the motherboard.
    • Remember to be gentle when handling the motherboard.
Conclusie
Maxwell Webb
631 Reputatie
5 handleidingen geschreven
Cal Poly, Team S2-G8, Maness Spring 2019 Lid van Cal Poly, Team S2-G8, Maness Spring 2019
CPSU-MANESS-S19S2G8
2 Leden
22 handleidingen geschreven
2 opmerkingen
where do you get a ps1 classic mini motherboard ?
blaqdemon69 - Antwoord
You would probably be cannibalizing a broken PS1 Classic for its motherboard. Perhaps "Parts Only."
Matt Latsha -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 68
Altijd: 3,418
