Playstation 3 Fan Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Playstation 3 Fan Replacement, Top Cover: step 1, image 1 of 2 Playstation 3 Fan Replacement, Top Cover: step 1, image 2 of 2
    • Remove the rubber screw cover near the hard drive cover with a spudger.
  2. Playstation 3 Fan Replacement: step 2, image 1 of 1
    • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
  3. Playstation 3 Fan Replacement: step 3, image 1 of 2 Playstation 3 Fan Replacement: step 3, image 2 of 2
    • Slide the top cover down about half an inch.
    • Lift the cover off of the PS3.
  4. Playstation 3 Fan Replacement: step 4, image 1 of 2 Playstation 3 Fan Replacement: step 4, image 2 of 2
    • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
    • One of the screws is shorter than the others. The short screw is marked in yellow.
  5. Playstation 3 Fan Replacement: step 5, image 1 of 3 Playstation 3 Fan Replacement: step 5, image 2 of 3 Playstation 3 Fan Replacement: step 5, image 3 of 3
    • You can now lift off the top cover.
  6. Playstation 3 Fan Replacement, Power Supply: step 6, image 1 of 2 Playstation 3 Fan Replacement, Power Supply: step 6, image 2 of 2
    • Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
    • Push down the tab on the connector to disconnect the wires.
    • Remove the two screws on the front of the power supply.
  7. Playstation 3 Fan Replacement: step 7, image 1 of 1
    • Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
  8. Playstation 3 Fan Replacement: step 8, image 1 of 2 Playstation 3 Fan Replacement: step 8, image 2 of 2
    • Remove the power supply by lifting it straight up.
  9. Playstation 3 Fan Replacement, Motherboard Enclosure: step 9, image 1 of 2 Playstation 3 Fan Replacement, Motherboard Enclosure: step 9, image 2 of 2
    • Unplug the optical drive power cable.
    • Detach the ribbon cable that connects the optical drive to the motherboard.
    • Set the optical drive aside.
  10. Playstation 3 Fan Replacement: step 10, image 1 of 2 Playstation 3 Fan Replacement: step 10, image 2 of 2
    • Remove three screws (Phillips #2) from the wireless board and antenna.
    • Detach the ribbon cable that connects the wireless board to the motherboard.
  11. Playstation 3 Fan Replacement: step 11, image 1 of 1
    • Remove nine screws (Phillips #2) from the perimeter of the metal plate covering the motherboard.
  12. Playstation 3 Fan Replacement: step 12, image 1 of 3 Playstation 3 Fan Replacement: step 12, image 2 of 3 Playstation 3 Fan Replacement: step 12, image 3 of 3
    • Remove the hard drive door with a spudger.
    • Lift the metal enclosure out of the plastic bottom case.
  13. Playstation 3 Fan Replacement, Fan: step 13, image 1 of 1
    • Remove the three screws (Phillips #2).
    • Disconnect the fan's power cable.
    • Lift the fan straight up and out.
iDeleted
2,101 Reputation
39 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,790
