Ga door naar hoofdinhoud
PlayStation Vita Wireless Card Replacement
Wat je nodig hebt
  1. PlayStation Vita Wireless Card Replacement, Case Separation: stap 1, afbeelding 1 van 2 PlayStation Vita Wireless Card Replacement, Case Separation: stap 1, afbeelding 2 van 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Wireless Card Replacement: stap 2, afbeelding 1 van 3 PlayStation Vita Wireless Card Replacement: stap 2, afbeelding 2 van 3 PlayStation Vita Wireless Card Replacement: stap 2, afbeelding 3 van 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Wireless Card Replacement: stap 3, afbeelding 1 van 2 PlayStation Vita Wireless Card Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Wireless Card Replacement: stap 4, afbeelding 1 van 3 PlayStation Vita Wireless Card Replacement: stap 4, afbeelding 2 van 3 PlayStation Vita Wireless Card Replacement: stap 4, afbeelding 3 van 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Wireless Card Replacement: stap 5, afbeelding 1 van 2 PlayStation Vita Wireless Card Replacement: stap 5, afbeelding 2 van 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
    One of the shoulder buttons fell out when I was doing this step, along with the piece holding it in place. They go back in just fine when reassembling but make sure that they are oriented properly, of course.
    klung - Antwoord
  6. PlayStation Vita Wireless Card Replacement: stap 6, afbeelding 1 van 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Wireless Card Replacement: stap 7, afbeelding 1 van 1
    • Free the battery cable by gently prying up on the connection with a spudger.
    Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
    Jimbo Jones - Antwoord
    This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
    ylimakiminna - Antwoord
    Yea I messed up there too. Is there a way to fix it?
    Alethia Henry - Antwoord
    This component was far more stubborn than the screen connector when it came to removal. I opted for a smaller tool than the spudger (small flat-head) and managed to disconnect it after determining the best bit size for the job. Screwdriver is metal, obviously, so being gentle helps to avoid damaging anything.
    klung - Antwoord
    broke the white part
    Benaya Miller - Antwoord
  8. PlayStation Vita Wireless Card Replacement: stap 8, afbeelding 1 van 1
    • Separate the front and rear cases.
  9. PlayStation Vita Wireless Card Replacement, Wireless Card: stap 9, afbeelding 1 van 3 PlayStation Vita Wireless Card Replacement, Wireless Card: stap 9, afbeelding 2 van 3 PlayStation Vita Wireless Card Replacement, Wireless Card: stap 9, afbeelding 3 van 3
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
    Step 9-11 only apply to the 3G version of the PS Vita.
    logicj83 - Antwoord
    Hello, I have the PCH-2001 model of the PS vita and the right analog stick went out. I ordered a replacement and the stick is slightly larger than the original. The original has a black rectangle on the back, the new version has the star version, which is what you have on this website as the replacement part. Any help here would be much appreciated. Thanks.
    Ben Ragains - Antwoord
    Can I install a WiFi motherboard on a 3g ps vita model 1100?
    fmind11 - Antwoord
  10. PlayStation Vita Wireless Card Replacement: stap 10, afbeelding 1 van 2 PlayStation Vita Wireless Card Replacement: stap 10, afbeelding 2 van 2
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Wireless Card Replacement: stap 11, afbeelding 1 van 2 PlayStation Vita Wireless Card Replacement: stap 11, afbeelding 2 van 2
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
    My screwdriver does not want to unscrew those. They won’t turn at all.
    Rei - Antwoord
    Got the same, used PH #0 and grabbed wireless card casing with fingers from the top to release pressure on screen and avoid (possibly) breaking it.
    Yuriy Zhyromskiy - Antwoord
    Some PS vita models seem to use a T2 screw instead of a PH#00. I’ve encountered this twice now.
    kaosjr kaosjr - Antwoord
    I replaced de wifi card but is still difficult to connect to wifi. Could it be the wifi antenna? which cable model is it?
    Fernando Diaz - Antwoord
    3G Vita 1000.
    I found that the PH00 head wouldn't actually fit in to the screw correctly. A PH000 fit but was still requiring a bit more force than seemed necessary. Also the card did not pop up when the screws were released and that's because Sony used a tacky pad under the card so needed a bit of prying up to get the angle.
    Paul Pimm - Antwoord
Conclusie
3 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
89.014 Reputatie
131 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.816 handleidingen geschreven
4 opmerkingen
i am takig my vita apart (moving all boards/chips into new oled lcd screen/ front part) and am having trouble taking the wifi chip out in order to take out the right button board, the screw closest to the right button board is i think stripped, is there an easy and non harming way to the motherboard of taking that screw out?
Saul Calderon - Antwoord
Rubber band .
Duck -
umm, just took mine apart and there isnt a card nor a card holder.... what?
Joe The total Lord - Antwoord
Then you have the Wi-Fi only version. Only the model with the 3G modem actually has that slot. This part is the 3G modem module. The actual Wi-Fi chip is on the mainboard not as a separate module.
ccfman2004 -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 98
Altijd: 13,381
