Ga door naar hoofdinhoud
PlayStation Vita Right Button Board Replacement
Wat je nodig hebt
  1. PlayStation Vita Right Button Board Replacement, Case Separation: stap 1, afbeelding 1 van 2 PlayStation Vita Right Button Board Replacement, Case Separation: stap 1, afbeelding 2 van 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Right Button Board Replacement: stap 2, afbeelding 1 van 3 PlayStation Vita Right Button Board Replacement: stap 2, afbeelding 2 van 3 PlayStation Vita Right Button Board Replacement: stap 2, afbeelding 3 van 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Right Button Board Replacement: stap 3, afbeelding 1 van 2 PlayStation Vita Right Button Board Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Right Button Board Replacement: stap 4, afbeelding 1 van 3 PlayStation Vita Right Button Board Replacement: stap 4, afbeelding 2 van 3 PlayStation Vita Right Button Board Replacement: stap 4, afbeelding 3 van 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Right Button Board Replacement: stap 5, afbeelding 1 van 2 PlayStation Vita Right Button Board Replacement: stap 5, afbeelding 2 van 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Right Button Board Replacement: stap 6, afbeelding 1 van 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Right Button Board Replacement: stap 7, afbeelding 1 van 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Right Button Board Replacement: stap 8, afbeelding 1 van 1
    • Separate the front and rear cases.
  9. PlayStation Vita Right Button Board Replacement, Wireless Card: stap 9, afbeelding 1 van 3 PlayStation Vita Right Button Board Replacement, Wireless Card: stap 9, afbeelding 2 van 3 PlayStation Vita Right Button Board Replacement, Wireless Card: stap 9, afbeelding 3 van 3
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
  10. PlayStation Vita Right Button Board Replacement: stap 10, afbeelding 1 van 2 PlayStation Vita Right Button Board Replacement: stap 10, afbeelding 2 van 2
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Right Button Board Replacement: stap 11, afbeelding 1 van 2 PlayStation Vita Right Button Board Replacement: stap 11, afbeelding 2 van 2
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
  12. PlayStation Vita Right Button Board Replacement, Right Shoulder Button: stap 12, afbeelding 1 van 3 PlayStation Vita Right Button Board Replacement, Right Shoulder Button: stap 12, afbeelding 2 van 3 PlayStation Vita Right Button Board Replacement, Right Shoulder Button: stap 12, afbeelding 3 van 3
    • Pry up the right shoulder button casing with a spudger and set it aside.
  13. PlayStation Vita Right Button Board Replacement: stap 13, afbeelding 1 van 1
    • Remove the translucent, plastic right shoulder button cover.
  14. PlayStation Vita Right Button Board Replacement: stap 14, afbeelding 1 van 3 PlayStation Vita Right Button Board Replacement: stap 14, afbeelding 2 van 3 PlayStation Vita Right Button Board Replacement: stap 14, afbeelding 3 van 3
    • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
    • Using tweezers, slide the flex cable out of the socket.
  15. PlayStation Vita Right Button Board Replacement: stap 15, afbeelding 1 van 2 PlayStation Vita Right Button Board Replacement: stap 15, afbeelding 2 van 2
    • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
  16. PlayStation Vita Right Button Board Replacement, Right Button Board: stap 16, afbeelding 1 van 2 PlayStation Vita Right Button Board Replacement, Right Button Board: stap 16, afbeelding 2 van 2
    • Using the pointy end of a spudger, detach the antenna cable on the right button board.
    • Remove the antenna cable.
  17. PlayStation Vita Right Button Board Replacement: stap 17, afbeelding 1 van 2 PlayStation Vita Right Button Board Replacement: stap 17, afbeelding 2 van 2
    • Using a spudger, pry up and release the ZIF socket on the right button board.
    • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  18. PlayStation Vita Right Button Board Replacement: stap 18, afbeelding 1 van 3 PlayStation Vita Right Button Board Replacement: stap 18, afbeelding 2 van 3 PlayStation Vita Right Button Board Replacement: stap 18, afbeelding 3 van 3
    • Release the tab on the small flex cable socket by prying up the tab with a spudger.
    • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  19. PlayStation Vita Right Button Board Replacement: stap 19, afbeelding 1 van 3 PlayStation Vita Right Button Board Replacement: stap 19, afbeelding 2 van 3 PlayStation Vita Right Button Board Replacement: stap 19, afbeelding 3 van 3
    • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
    • Remove the metal bracket, using a spudger as necessary to lift it out.
  20. PlayStation Vita Right Button Board Replacement: stap 20, afbeelding 1 van 3 PlayStation Vita Right Button Board Replacement: stap 20, afbeelding 2 van 3 PlayStation Vita Right Button Board Replacement: stap 20, afbeelding 3 van 3
    • Use a spudger to free the right button board by prying up from the bottom right corner of board.
    • Gently lift the right button board out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brittany McCrigler
89.011 Reputatie
131 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.732 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 65
Altijd: 7,792
