Ga door naar hoofdinhoud
PlayStation Vita Rear Panel Replacement
Wat je nodig hebt
  1. PlayStation Vita Rear Panel Replacement, Case Separation: stap 1, afbeelding 1 van 2 PlayStation Vita Rear Panel Replacement, Case Separation: stap 1, afbeelding 2 van 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Rear Panel Replacement: stap 2, afbeelding 1 van 3 PlayStation Vita Rear Panel Replacement: stap 2, afbeelding 2 van 3 PlayStation Vita Rear Panel Replacement: stap 2, afbeelding 3 van 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Rear Panel Replacement: stap 3, afbeelding 1 van 2 PlayStation Vita Rear Panel Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Rear Panel Replacement: stap 4, afbeelding 1 van 3 PlayStation Vita Rear Panel Replacement: stap 4, afbeelding 2 van 3 PlayStation Vita Rear Panel Replacement: stap 4, afbeelding 3 van 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Rear Panel Replacement: stap 5, afbeelding 1 van 2 PlayStation Vita Rear Panel Replacement: stap 5, afbeelding 2 van 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Rear Panel Replacement: stap 6, afbeelding 1 van 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Rear Panel Replacement: stap 7, afbeelding 1 van 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Rear Panel Replacement: stap 8, afbeelding 1 van 1
    • Separate the front and rear cases.
  9. PlayStation Vita Rear Panel Replacement, Battery: stap 9, afbeelding 1 van 2 PlayStation Vita Rear Panel Replacement, Battery: stap 9, afbeelding 2 van 2
    • With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
    • The easiest access to the battery cable retainer is where the battery cable comes out.
    • You can also use the two small tabs on the side of the cable retainer. Locate the tabs and release one at a time. Be a little careful not to push the cover in and re-lock it.
  10. PlayStation Vita Rear Panel Replacement: stap 10, afbeelding 1 van 2 PlayStation Vita Rear Panel Replacement: stap 10, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
    • Remove the plastic battery retaining bar.
  11. PlayStation Vita Rear Panel Replacement: stap 11, afbeelding 1 van 3 PlayStation Vita Rear Panel Replacement: stap 11, afbeelding 2 van 3 PlayStation Vita Rear Panel Replacement: stap 11, afbeelding 3 van 3
    • Using your finger or a spudger, lift the battery out and remove it.
    • Guide the battery wires through the hole in the back casing as you remove the battery.
  12. PlayStation Vita Rear Panel Replacement, Rear Panel: stap 12, afbeelding 1 van 3 PlayStation Vita Rear Panel Replacement, Rear Panel: stap 12, afbeelding 2 van 3 PlayStation Vita Rear Panel Replacement, Rear Panel: stap 12, afbeelding 3 van 3
    • Slide the spuder between the right speaker and the rear casing.
    • Using a spudger, gently peel up the right speaker from the light adhesive connecting it to casing.
    • Remove the right speaker.
  13. PlayStation Vita Rear Panel Replacement: stap 13, afbeelding 1 van 3 PlayStation Vita Rear Panel Replacement: stap 13, afbeelding 2 van 3 PlayStation Vita Rear Panel Replacement: stap 13, afbeelding 3 van 3
    • Slide the spudger between the left speaker and the rear casing.
    • Using a spudger, gently peel up the left speaker from the light adhesive connecting it to casing.
    • Remove the left speaker.
  14. PlayStation Vita Rear Panel Replacement: stap 14, afbeelding 1 van 1
    • The rear panel remains.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
89.011 Reputatie
131 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.734 handleidingen geschreven
5 opmerkingen
I really enjoyed Your article ! I'm about to replace the touch pad, i got a Vita recently but it has some Heavy scuffs. I've seen the back touch pad has adhesive attached on it. I bought a replacement On Ebay. I'm not sure if the replacement has adhesive with it. If it doesn't what would be your guys Thoughts on what i should use?
Daniel - Antwoord
lol you will need some kind of adhesive its called common sense if Sony use it you use it simple
TH3ORY -
I can't get pass Step 1. I can take out the bottom left screw of the rear touchpad but I can't take out the other 3. I bought a used Vita and there is a screw that turns but does not gout up. What should I do?
kken07655 - Antwoord
In the part that remains after complete disassembly, what are the two double pins at the top for, which later come into contact with the motherboard? I already have a new panel, but it has absolutely nothing except this one contact in the lower right part ...
Kamil Dębiec - Antwoord
Those are wifi antennas. You can get it out put it in to the new panel.
repairguy69 -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 74
Afgelopen 30 dagen: 338
Altijd: 30,247
