Ga door naar hoofdinhoud
PlayStation Vita Rear Camera Replacement
Wat je nodig hebt
  1. PlayStation Vita Rear Camera Replacement, Case Separation: stap 1, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement, Case Separation: stap 1, afbeelding 2 van 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Rear Camera Replacement: stap 2, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement: stap 2, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement: stap 2, afbeelding 3 van 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Rear Camera Replacement: stap 3, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Rear Camera Replacement: stap 4, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement: stap 4, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement: stap 4, afbeelding 3 van 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Rear Camera Replacement: stap 5, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 5, afbeelding 2 van 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
    One of the shoulder buttons fell out when I was doing this step, along with the piece holding it in place. They go back in just fine when reassembling but make sure that they are oriented properly, of course.
    klung - Antwoord
  6. PlayStation Vita Rear Camera Replacement: stap 6, afbeelding 1 van 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Rear Camera Replacement: stap 7, afbeelding 1 van 1
    • Free the battery cable by gently prying up on the connection with a spudger.
    Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
    Jimbo Jones - Antwoord
    This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
    ylimakiminna - Antwoord
    Yea I messed up there too. Is there a way to fix it?
    Alethia Henry - Antwoord
    This component was far more stubborn than the screen connector when it came to removal. I opted for a smaller tool than the spudger (small flat-head) and managed to disconnect it after determining the best bit size for the job. Screwdriver is metal, obviously, so being gentle helps to avoid damaging anything.
    klung - Antwoord
    broke the white part
    Benaya Miller - Antwoord
  8. PlayStation Vita Rear Camera Replacement: stap 8, afbeelding 1 van 1
    • Separate the front and rear cases.
  9. PlayStation Vita Rear Camera Replacement, Wireless Card: stap 9, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement, Wireless Card: stap 9, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement, Wireless Card: stap 9, afbeelding 3 van 3
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
    Step 9-11 only apply to the 3G version of the PS Vita.
    logicj83 - Antwoord
    Hello, I have the PCH-2001 model of the PS vita and the right analog stick went out. I ordered a replacement and the stick is slightly larger than the original. The original has a black rectangle on the back, the new version has the star version, which is what you have on this website as the replacement part. Any help here would be much appreciated. Thanks.
    Ben Ragains - Antwoord
    Can I install a WiFi motherboard on a 3g ps vita model 1100?
    fmind11 - Antwoord
  10. PlayStation Vita Rear Camera Replacement: stap 10, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 10, afbeelding 2 van 2
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Rear Camera Replacement: stap 11, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 11, afbeelding 2 van 2
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
    My screwdriver does not want to unscrew those. They won’t turn at all.
    Rei - Antwoord
    Got the same, used PH #0 and grabbed wireless card casing with fingers from the top to release pressure on screen and avoid (possibly) breaking it.
    Yuriy Zhyromskiy - Antwoord
    Some PS vita models seem to use a T2 screw instead of a PH#00. I’ve encountered this twice now.
    kaosjr kaosjr - Antwoord
    I replaced de wifi card but is still difficult to connect to wifi. Could it be the wifi antenna? which cable model is it?
    Fernando Diaz - Antwoord
    3G Vita 1000.
    I found that the PH00 head wouldn't actually fit in to the screw correctly. A PH000 fit but was still requiring a bit more force than seemed necessary. Also the card did not pop up when the screws were released and that's because Sony used a tacky pad under the card so needed a bit of prying up to get the angle.
    Paul Pimm - Antwoord
  12. PlayStation Vita Rear Camera Replacement, Right Shoulder Button: stap 12, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement, Right Shoulder Button: stap 12, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement, Right Shoulder Button: stap 12, afbeelding 3 van 3
    • Pry up the right shoulder button casing with a spudger and set it aside.
    Is this really necessary?
    fmind11 - Antwoord
  13. PlayStation Vita Rear Camera Replacement: stap 13, afbeelding 1 van 1
    • Remove the translucent, plastic right shoulder button cover.
  14. PlayStation Vita Rear Camera Replacement: stap 14, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement: stap 14, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement: stap 14, afbeelding 3 van 3
    • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
    • Using tweezers, slide the flex cable out of the socket.
  15. PlayStation Vita Rear Camera Replacement: stap 15, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 15, afbeelding 2 van 2
    • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
  16. PlayStation Vita Rear Camera Replacement, Right Button Board: stap 16, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement, Right Button Board: stap 16, afbeelding 2 van 2
    • Using the pointy end of a spudger, detach the antenna cable on the right button board.
    • Remove the antenna cable.
  17. PlayStation Vita Rear Camera Replacement: stap 17, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 17, afbeelding 2 van 2
    • Using a spudger, pry up and release the ZIF socket on the right button board.
    • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  18. PlayStation Vita Rear Camera Replacement: stap 18, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement: stap 18, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement: stap 18, afbeelding 3 van 3
    • Release the tab on the small flex cable socket by prying up the tab with a spudger.
    • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  19. PlayStation Vita Rear Camera Replacement: stap 19, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement: stap 19, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement: stap 19, afbeelding 3 van 3
    • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
    • Remove the metal bracket, using a spudger as necessary to lift it out.
  20. PlayStation Vita Rear Camera Replacement: stap 20, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement: stap 20, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement: stap 20, afbeelding 3 van 3
    • Use a spudger to free the right button board by prying up from the bottom right corner of board.
    • Gently lift the right button board out.
  21. PlayStation Vita Rear Camera Replacement, Left Shoulder Button: stap 21, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement, Left Shoulder Button: stap 21, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement, Left Shoulder Button: stap 21, afbeelding 3 van 3
    • Pry up the left shoulder button casing with a spudger.
    • Remove the left shoulder button casing.
  22. PlayStation Vita Rear Camera Replacement: stap 22, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 22, afbeelding 2 van 2
    • Remove the translucent, plastic left shoulder button cover.
  23. PlayStation Vita Rear Camera Replacement: stap 23, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement: stap 23, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement: stap 23, afbeelding 3 van 3
    • Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
    • Be careful to not break off this small black tab!
    • Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
    broke the small black tab, what happens if I just go without it??
    Nicolas Porfirio - Antwoord
  24. PlayStation Vita Rear Camera Replacement: stap 24, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 24, afbeelding 2 van 2
    • Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
    This step is unneccesary.
    Alexander Mayatsky - Antwoord
  25. PlayStation Vita Rear Camera Replacement, Left Button Board: stap 25, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement, Left Button Board: stap 25, afbeelding 2 van 2
    • Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
    • Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
    Este paso NO es necesario si tu PSVita no tiene lector de tarjeta SIM. Ve directamente al paso 15.
    Parappa The Rapper - Antwoord
  26. PlayStation Vita Rear Camera Replacement: stap 26, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement: stap 26, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement: stap 26, afbeelding 3 van 3
    • Use a spudger to release the tab between the SIM card reader and the back casing assembly.
    • Lift the SIM card reader off the back casing assembly.
    This board is not present in the Wifi only version, only the 3G/Wifi version.
    dodo - Antwoord
  27. PlayStation Vita Rear Camera Replacement: stap 27, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 27, afbeelding 2 van 2
    • Release the plastic tab on the small flex cable socket by prying it up with a spudger.
    • Using tweezers, gently remove the small flex cable from the socket, and rest it out of the way.
  28. PlayStation Vita Rear Camera Replacement: stap 28, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 28, afbeelding 2 van 2
    • Use a spudger to lift up the tab on the large ZIF socket.
    • Gently pull the flex cable out of the ZIF socket, and rest it out of the way.
  29. PlayStation Vita Rear Camera Replacement: stap 29, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 29, afbeelding 2 van 2
    • Disconnect the white Wi-Fi antenna cable with a spudger.
    • Remove the Wi-Fi antenna cable.
    This connector isn't present in the Wifi only version, just the 3G/Wifi version.
    dodo - Antwoord
  30. PlayStation Vita Rear Camera Replacement: stap 30, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement: stap 30, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement: stap 30, afbeelding 3 van 3
    • Using a Phillips #00 screwdriver, remove the six screws on the two metal brackets:
    • Two 5.0mm, blue screws on the L-bracket securing the upper left button board to the motherboard.
    • Four 5.0mm, blue screws on the square bracket securing the lower left button board to the motherboard.
    What is the loose looking cable in this photo?
    Dallon Verhaeghe - Antwoord
  31. PlayStation Vita Rear Camera Replacement: stap 31, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement: stap 31, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement: stap 31, afbeelding 3 van 3
    • Starting from the upper left corner, use a spudger to pry up and remove the left button board.
  32. PlayStation Vita Rear Camera Replacement, Rear Camera: stap 32, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement, Rear Camera: stap 32, afbeelding 2 van 2
    • Using the pointy end of a spudger, pry up and release the GPS antenna cable from the motherboard.
    • Remove the GPS antenna cable.
  33. PlayStation Vita Rear Camera Replacement: stap 33, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 33, afbeelding 2 van 2
    • Release the camera flex cable socket by prying up on the tab with a spudger.
  34. PlayStation Vita Rear Camera Replacement: stap 34, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 34, afbeelding 2 van 2
    • Using a spudger, gently pry up on the camera.
    • Work your way under the camera and along the camera flex cable, using the spudger to peel away the adhesive, freeing the camera.
  35. PlayStation Vita Rear Camera Replacement: stap 35, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 35, afbeelding 2 van 2
    • Carefully lift and remove the camera, sliding the flex cable out of the open connector socket.
  36. PlayStation Vita Rear Camera Replacement: stap 36, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 36, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, remove the 6.3mm screw beneath the camera.
    • Lift and remove the metal camera bracket.
  37. PlayStation Vita Rear Camera Replacement: stap 37, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 37, afbeelding 2 van 2
    • With the help of a spudger, lift and release the tab on the blue flex cable socket.
  38. PlayStation Vita Rear Camera Replacement: stap 38, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 38, afbeelding 2 van 2
    • Using tweezers, gently pull the blue power flex cable out of the socket, and rest it out of the way.
  39. PlayStation Vita Rear Camera Replacement: stap 39, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the two pink, 4.4mm screws securing the motherboard.
  40. PlayStation Vita Rear Camera Replacement: stap 40, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement: stap 40, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement: stap 40, afbeelding 3 van 3
    • Gently peel the rubber tab of the game port cover off the plastic casing pins.
    • Remove the game port cover.
  41. PlayStation Vita Rear Camera Replacement: stap 41, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement: stap 41, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement: stap 41, afbeelding 3 van 3
    • Gently peel the rubber tab of the accessory port cover off the plastic casing pins.
    • Remove the accessory port cover.
  42. PlayStation Vita Rear Camera Replacement: stap 42, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement: stap 42, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement: stap 42, afbeelding 3 van 3
    • Starting at the upper right hand corner, use a spudger to gently lift the motherboard out of the casing assembly.
    • The motherboard is still attached to the casing by a connector on the back of the motherboard. Do not pull the motherboard all the way out, or you may damage the connector.
  43. PlayStation Vita Rear Camera Replacement: stap 43, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement: stap 43, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement: stap 43, afbeelding 3 van 3
    • Lift the motherboard out and identify the OLED connector still attaching the motherboard to the casing.
    • Holding the Vita on its side, use a spudger to gently pry off the OLED connector from the motherboard.
    • Be sure to hold the motherboard while you release the connector as this will free the motherboard. If you are not holding the motherboard, it will fall.
  44. PlayStation Vita Rear Camera Replacement: stap 44, afbeelding 1 van 1
    • Completely separate the motherboard from the case. Set the case aside.
  45. PlayStation Vita Rear Camera Replacement: stap 45, afbeelding 1 van 2 PlayStation Vita Rear Camera Replacement: stap 45, afbeelding 2 van 2
    • Flip the motherboard over so that the rear camera is facing you on the right.
    • Release the rear camera flex cable socket by prying up on the tab with a spudger. Leave the socket open.
  46. PlayStation Vita Rear Camera Replacement: stap 46, afbeelding 1 van 3 PlayStation Vita Rear Camera Replacement: stap 46, afbeelding 2 van 3 PlayStation Vita Rear Camera Replacement: stap 46, afbeelding 3 van 3
    • Gently pull the rear camera out of the flex cable socket.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
89.014 Reputatie
131 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
Één opmerking
This is not it's rear-facing camera though - it is it's front-facing camera.
iFixOmaha LLC - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 5,322
