Inleiding
This guide takes you through the process of installing the left shoulder button on the PlayStation Vita.
Wat je nodig hebt
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Pry up the left shoulder button casing with a spudger.
Remove the left shoulder button casing.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
5 andere personen hebben deze handleiding voltooid.
