Ga door naar hoofdinhoud
PlayStation Vita Left Shoulder Button Replacement
Wat je nodig hebt
  1. PlayStation Vita Left Shoulder Button Replacement, Case Separation: stap 1, afbeelding 1 van 2 PlayStation Vita Left Shoulder Button Replacement, Case Separation: stap 1, afbeelding 2 van 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Left Shoulder Button Replacement: stap 2, afbeelding 1 van 3 PlayStation Vita Left Shoulder Button Replacement: stap 2, afbeelding 2 van 3 PlayStation Vita Left Shoulder Button Replacement: stap 2, afbeelding 3 van 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Left Shoulder Button Replacement: stap 3, afbeelding 1 van 2 PlayStation Vita Left Shoulder Button Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Left Shoulder Button Replacement: stap 4, afbeelding 1 van 3 PlayStation Vita Left Shoulder Button Replacement: stap 4, afbeelding 2 van 3 PlayStation Vita Left Shoulder Button Replacement: stap 4, afbeelding 3 van 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Left Shoulder Button Replacement: stap 5, afbeelding 1 van 2 PlayStation Vita Left Shoulder Button Replacement: stap 5, afbeelding 2 van 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Left Shoulder Button Replacement: stap 6, afbeelding 1 van 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Left Shoulder Button Replacement: stap 7, afbeelding 1 van 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Left Shoulder Button Replacement: stap 8, afbeelding 1 van 1
    • Separate the front and rear cases.
  9. PlayStation Vita Left Shoulder Button Replacement, Left Shoulder Button: stap 9, afbeelding 1 van 3 PlayStation Vita Left Shoulder Button Replacement, Left Shoulder Button: stap 9, afbeelding 2 van 3 PlayStation Vita Left Shoulder Button Replacement, Left Shoulder Button: stap 9, afbeelding 3 van 3
    • Pry up the left shoulder button casing with a spudger.
    • Remove the left shoulder button casing.
  10. PlayStation Vita Left Shoulder Button Replacement: stap 10, afbeelding 1 van 2 PlayStation Vita Left Shoulder Button Replacement: stap 10, afbeelding 2 van 2
    • Remove the translucent, plastic left shoulder button cover.
  11. PlayStation Vita Left Shoulder Button Replacement: stap 11, afbeelding 1 van 3 PlayStation Vita Left Shoulder Button Replacement: stap 11, afbeelding 2 van 3 PlayStation Vita Left Shoulder Button Replacement: stap 11, afbeelding 3 van 3
    • Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
    • Be careful to not break off this small black tab!
    • Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
  12. PlayStation Vita Left Shoulder Button Replacement: stap 12, afbeelding 1 van 2 PlayStation Vita Left Shoulder Button Replacement: stap 12, afbeelding 2 van 2
    • Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
89.011 Reputatie
131 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.732 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 66
Altijd: 12,477
