Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide takes you through the process of installing the left button board. This board controls the directional pad (D-pad) and PS button.
  1. Power off and remove the memory card. Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. Using your fingernail or a spudger, pry open the accessory port cover on the top of the device. Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover. Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port. Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases. Continue working your way around the device gently prying it open. There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together. Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. Free the battery cable by gently prying up on the connection with a spudger.
    • Free the battery cable by gently prying up on the connection with a spudger.
    Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
    Jimbo Jones - Antwoord
    This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
    ylimakiminna - Antwoord
    Yea I messed up there too. Is there a way to fix it?
    Alethia Henry - Antwoord
  8. De essentiële toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  9. Separate the front and rear cases.
    • Separate the front and rear cases.
  10. Pry up the left shoulder button casing with a spudger. Remove the left shoulder button casing. Remove the left shoulder button casing.
    • Pry up the left shoulder button casing with a spudger.
    • Remove the left shoulder button casing.
  11. Remove the translucent, plastic left shoulder button cover. Remove the translucent, plastic left shoulder button cover.
    • Remove the translucent, plastic left shoulder button cover.
  12. Release the left shoulder button flex cable socket by using a spudger to pry open the tab. Be careful to not break off this small black tab! Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
    • Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
    • Be careful to not break off this small black tab!
    • Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
  13. Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing. Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
    • Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
    This step is unneccesary.
    Alexander Mayatsky - Antwoord
  14. Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader. Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
    • Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
    • Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
  15. Use a spudger to release the tab between the SIM card reader and the back casing assembly. Lift the SIM card reader off the back casing assembly. Lift the SIM card reader off the back casing assembly.
    • Use a spudger to release the tab between the SIM card reader and the back casing assembly.
    • Lift the SIM card reader off the back casing assembly.
    This board is not present in the Wifi only version, only the 3G/Wifi version.
    dodo - Antwoord
  16. Release the plastic tab on the small flex cable socket by prying it up with a spudger. Using tweezers, gently remove the small flex cable from the socket, and rest it out of the way.
    • Release the plastic tab on the small flex cable socket by prying it up with a spudger.
    • Using tweezers, gently remove the small flex cable from the socket, and rest it out of the way.
  17. Use a spudger to lift up the tab on the large ZIF socket. Gently pull the flex cable out of the ZIF socket, and rest it out of the way.
    • Use a spudger to lift up the tab on the large ZIF socket.
    • Gently pull the flex cable out of the ZIF socket, and rest it out of the way.
  18. Disconnect the white Wi-Fi antenna cable with a spudger. Remove the Wi-Fi antenna cable.
    • Disconnect the white Wi-Fi antenna cable with a spudger.
    • Remove the Wi-Fi antenna cable.
    This connector isn't present in the Wifi only version, just the 3G/Wifi version.
    dodo - Antwoord
  19. Using a Phillips #00 screwdriver, remove the six screws on the two metal brackets: Two 5.0mm, blue screws on the L-bracket securing the upper left button board to the motherboard. Four 5.0mm, blue screws on the square bracket securing the lower left button board to the motherboard.
    • Using a Phillips #00 screwdriver, remove the six screws on the two metal brackets:
    • Two 5.0mm, blue screws on the L-bracket securing the upper left button board to the motherboard.
    • Four 5.0mm, blue screws on the square bracket securing the lower left button board to the motherboard.
    What is the loose looking cable in this photo?
    Dallon Verhaeghe - Antwoord
  20. Starting from the upper left corner, use a spudger to pry up and remove the left button board. Starting from the upper left corner, use a spudger to pry up and remove the left button board. Starting from the upper left corner, use a spudger to pry up and remove the left button board.
    • Starting from the upper left corner, use a spudger to pry up and remove the left button board.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
85.067 Reputatie
132 handleidingen geschreven
good idea but i need help with the big fat one on the left because it went into water by an accsident and its not moving and its like locked or like jammed. I put it in the boiler for a while and i took it out after then it still was jammed locked.
Morganstutte@hotmail.com - Antwoord
please can you tell me how to fix the big fat button on the left because water went in it and i tryed putting it in the boiler for a while then i took it out and the button was still not working it like jammed locked it dosn't work. PLEEEEEEAAAAASSSSEEE HEEELLLPPP MEEEEEE!!!!!!!!!!!!!!!!!!
Make a video of it please!!!!
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 69
Altijd: 6,358
