Inleiding
This guide takes you through the process of installing the GPS antenna cable. This is the middle antenna cable on the wireless card.
Onderdelen
Geen onderdelen opgegeven.
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Using the pointy end of the spudger, gently pry the GPS antenna cable off the wireless card.
Bijna klaar!
Conclusie
