Ga door naar hoofdinhoud
PlayStation Vita Camera Replacement
Wat je nodig hebt
  1. PlayStation Vita Camera Replacement, Case Separation: stap 1, afbeelding 1 van 2 PlayStation Vita Camera Replacement, Case Separation: stap 1, afbeelding 2 van 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Camera Replacement: stap 2, afbeelding 1 van 3 PlayStation Vita Camera Replacement: stap 2, afbeelding 2 van 3 PlayStation Vita Camera Replacement: stap 2, afbeelding 3 van 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Camera Replacement: stap 3, afbeelding 1 van 2 PlayStation Vita Camera Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Camera Replacement: stap 4, afbeelding 1 van 3 PlayStation Vita Camera Replacement: stap 4, afbeelding 2 van 3 PlayStation Vita Camera Replacement: stap 4, afbeelding 3 van 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Camera Replacement: stap 5, afbeelding 1 van 2 PlayStation Vita Camera Replacement: stap 5, afbeelding 2 van 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Camera Replacement: stap 6, afbeelding 1 van 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Camera Replacement: stap 7, afbeelding 1 van 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Camera Replacement: stap 8, afbeelding 1 van 1
    • Separate the front and rear cases.
  9. PlayStation Vita Camera Replacement, Camera: stap 9, afbeelding 1 van 2 PlayStation Vita Camera Replacement, Camera: stap 9, afbeelding 2 van 2
    • Release the camera flex cable socket by prying up on the tab with a spudger. Leave the socket open.
  10. PlayStation Vita Camera Replacement: stap 10, afbeelding 1 van 3 PlayStation Vita Camera Replacement: stap 10, afbeelding 2 van 3 PlayStation Vita Camera Replacement: stap 10, afbeelding 3 van 3
    • Using a spudger, gently pry up the camera.
    • Work your way under the camera and along the camera flex cable, using the pointy tip of the spudger to peel away the adhesive, freeing the camera.
    • Carefully lift and remove the camera.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
89.748 Reputatie
142 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.535 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 91
Altijd: 9,579
