Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
A damaged or broken cooling fan can make your system overheat so it is important to replace it if that happens in order to prevent any further damage to the system.
  1. On one side of the console (the side adjacent to the fan vent), there will be two 6 mm screws. Unscrew them with a PH #000 screwdriver. On one side of the console (the side adjacent to the fan vent), there will be two 6 mm screws. Unscrew them with a PH #000 screwdriver. On one side of the console (the side adjacent to the fan vent), there will be two 6 mm screws. Unscrew them with a PH #000 screwdriver.
    • On one side of the console (the side adjacent to the fan vent), there will be two 6 mm screws. Unscrew them with a PH #000 screwdriver.
  2. Press and slide the side panel (it will have the two ports) back to reveal an additional 6 mm screw. Unscrew the 6mm screw with a PH #000 screwdriver. Unscrew the 6mm screw with a PH #000 screwdriver.
    • Press and slide the side panel (it will have the two ports) back to reveal an additional 6 mm screw.
    • Unscrew the 6mm screw with a PH #000 screwdriver.
  3. Slide the panel back into place. Slide the panel back into place.
    • Slide the panel back into place.
  4. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  5. Using a plastic opening tool, carefully pry the panel from the main console to reveal the HDMI ports. You will probably need to lift it on both sides in order for the panel to come loose. You will probably need to lift it on both sides in order for the panel to come loose.
    • Using a plastic opening tool, carefully pry the panel from the main console to reveal the HDMI ports.
    • You will probably need to lift it on both sides in order for the panel to come loose.
  6. Turn the console over.
    • Turn the console over.
    • Unscrew the two 9 mm screws with a PH #000 screwdriver.
  7. With the plastic opening tool, carefully pry the console shell panel free and lift it away. With the plastic opening tool, carefully pry the console shell panel free and lift it away.
    • With the plastic opening tool, carefully pry the console shell panel free and lift it away.
  8. Using tweezers, carefully pull the multi colored bundled cable from its port connecting the fan to the console. Carefully lift the fan and its wiring from the device.
    • Using tweezers, carefully pull the multi colored bundled cable from its port connecting the fan to the console.
    • Carefully lift the fan and its wiring from the device.
    • Be mindful of damaging the wires.
    • Take care to keep your fingers away from the fan blades.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Sarah Shand
1.494 Reputatie
7 handleidingen geschreven
USF Tampa, Team S3-G1, Sullivan Spring 2017 Lid van USF Tampa, Team S3-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G1
3 Leden
13 handleidingen geschreven
Where do I get a replacement fan tho?
Ponos King - Antwoord
I think is a 3x3 cm fan, alliexpres has some, but what voltage?
crus - Antwoord
5V is what i have read
Ethan Amos -
Reference for fan when I have replaced mine : DELTA ELECTRONICS MODEL : ASB0305MA-01 DC 5V 0.19A
herossuperman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 50
Afgelopen 30 dagen: 226
Altijd: 4,702
